Effect of Using Battery Adapter Cords
Old 09-19-2014, 09:45 PM
garyp1029
Default Effect of Using Battery Adapter Cords
To what extent does using a 2"-3" long battery connector adapter cable (rather than cutting off the original connector and soldering on the connector of choice) effect the flow of power getting to the motor? Significantly? Makes little difference? Thanks. Gary
garyp1029 is offline
Old 09-19-2014, 09:57 PM
pmullen503
If the wire is adequately sized and the connections sound, it makes a negligible difference. Do the wiring and connectors stay cool? Then don't worry.
pmullen503 is offline
Old 09-19-2014, 10:29 PM
Maybe a few hundredths of an ohm of added resistance, resulting in a nearly impossible to measure reduction of power.
A well made adapter is not a problem.
In some cases I need over 2 FEET of wire between battery and ESC... then the issue is an inductance spike which makes it a good idea to add more capacitors.
Still negligible effect on power.
Old 09-20-2014, 06:33 AM
Wrongway-Feldman
Wrongway-Feldman's Avatar
I wouldn't worry too much about using them. I got tired of changing the ends of every ESC and battery I bought and now have adapters that go from every type of connector to any other type.
For most applications you won't have a problem. When you get to the high amp configurations just make sure the adapter is rated for the power draw.
Wrongway-Feldman is offline
Old 09-20-2014, 12:56 PM
Siberianhusky
Using an adapter won't amke much difference as people have said, but I find it much easier to standardize on a single type of connector and use them on every similar sized setup.
Most plane guys seem to hate them but I always use plain old bullet connectors, same size on motors and batteries. Hold over from running a lot of electric boats, use 6.5mm bullets for the boats. Big amp loads!
Connectors are much cheaper if you buy from a big electronics supply house in "bulk" can get 20 sets for less than 3 sets from a hobby shop. I buy from Digikey.
Siberianhusky is offline
Old 09-20-2014, 07:15 PM
road king 97
old hat
road king 97's Avatar
I bought one connector changing deans to the blue things e-flight batterys use and it flew the same on my sons apprentice . I could have just cut the battery plug end off and changed it to deans but iam getting lazy in my old age. lol joe
road king 97 is offline
Old 09-20-2014, 07:20 PM
Yeah, unless you are pulling sky high current through the wires it's not going to make any significant difference.
I personally prefer to solder on the correct connector, more to keep the installation neat and tidy than for any performance concern.
Old 09-20-2014, 07:29 PM
road king 97
old hat
Yep i do to but on smaller planes or a trainer its not going to hurt anything. If it was a 90 size electrict heli then thats another story . I have a friend flying them that big and i stand back when they plug the batterys to the esc because of large sparking . lol joe
Old 09-20-2014, 07:37 PM
I have adaptors ... I use both Deans and XT60's ...
The Deans are slightly smaller than XT60's ... and suit some of my models better. There are times I want to use those Deans batts in my XT60 machines ...
My only concern with adaptors - is the extra connection and risk of lost power ... but careful use and make-up - sees little problem.
Old 09-20-2014, 07:55 PM
road king 97
old hat
Yea i found a adapter with thicker wire and bought it when i did it as to try and not loose any power . joe
05-28-2020 10:50 PM
10-11-2016 02:52 AM
25
09-09-2013 12:47 AM
03-11-2012 03:40 AM
Otonzer
02-26-2012 01:01 AM
Quick Reply: Effect of Using Battery Adapter Cords
Page generated in 0.08510 seconds with 13 queries
