Motors
Old 08-06-2006, 06:55 PM
Richard Parkes
Default Motors
I have been running two Komodo KH2407-16 brushless motors. They produce a wonderful 105W and 24oz thrust with a 3 cell and a 9 x 4.5 prop. With 10A max Im getting great flight times from a 1100maH LiPo.
They have a 3.2mm shaft that the manufacturere calls hardened. However, even with a prop touch on a grass field when the wheels dip into a hole I have been getting bent shafts. I reckion to replace a shaft every 2nd time I go flying. Ive suggested to Komodo that they make a strionger shaft.
Does anyone have experience of this motor, or similar shaft bending problems ?
Richard Parkes is offline
Old 08-06-2006, 07:27 PM
randey
Get a prop saver held on with rubber O ring
randey is offline
Old 08-06-2006, 07:48 PM
Solid Hit
Just call me ... Bill
Solid Hit's Avatar
I agree 100% with randey.
When I fly at home, I have a problem with rough ground. The prop saver has saved me a bundle on wrecked shafts and props. Instead of "0" rings, I use the tiny rubberbands that girls use for their hair. 2 of them works on a prop work great and they will give when your prop hits the ground
Solid Hit is offline
Old 08-06-2006, 11:17 PM
Richard Parkes
Default Bent shafts
Ive seen 100Watts quoted on thsi site as a cut off for using Prop savers - is this real ?
However my problem isnt broken props they last just fine, I have not boken one yet, its bent shafts in the motor.
Richard
Old 08-06-2006, 11:49 PM
B.L.E.
multi-hundredaire
Richard
"Prop saver" is kind of a misnomer, they are really "shaft savers".
B.L.E. is offline
Old 08-07-2006, 02:59 AM
Solid Hit
Solid Hit's Avatar
I'm using a prop saver on an UltraFly B/06 rated at 150+ watts with no problems
Old 08-07-2006, 03:01 AM
Solid Hit
Solid Hit's Avatar
I'm using a prop saver on an UltraFly B/06 rated at 150+ watts with no problems flying my Mini Ultra Stick.
Old 08-07-2006, 08:13 PM
Richard Parkes
Do you use the standard approach of an O ring and a prop saver at this power level, or do use another technique ?
My particular setup is fitted with a 9 x 4.5 spinning at 8040 rpm and 24.9 noz thrust at full power.
Old 08-10-2006, 08:10 PM
Solid Hit
Solid Hit's Avatar
I'm using an APC 9x6 on my B/06 and it turns at about 7400 rpm. I don't know the thrust. I don't have any more "0" rings so I'm using rubberbands.
Old 08-10-2006, 08:17 PM
Rugar
FAA# OUTLAW!
Rugar's Avatar
You can get "0" rings at your local Hardware store. Ive read of some guys going to a Medical Supply store and getting some surgical tubing and then cutting out their own "0" rings from it. I think they were using 3/8 tubing if I remember correctly.
Rugar is offline
Old 08-10-2006, 08:57 PM
Solid Hit
Solid Hit's Avatar
Smile
.... but these little rubber bands that my daughter uses are just the right size and cost about $1.00 for somewhere around a million of them. I use two per prop and change them at the start of each flying session. That way I don't worry about nicked or stretched "0" rings. (And they come in nice colors).
Lancifer
Brushless Motor Construction
9
07-26-2008 04:57 PM
Jollyroger
14
08-10-2007 03:23 PM
adamdb
07-14-2007 08:43 AM
re3626
04-23-2006 12:39 AM
ms08
03-22-2006 07:56 PM
Quick Reply: Motors
Page generated in 0.16985 seconds with 13 queries
