E-Flite Extra 260 wrong motor setup?
Old 12-18-2007, 03:27 AM
CJQ
Default E-Flite Extra 260 wrong motor setup?
I just purchased a E-flite Extra 260 3D 480 from a local hobbie shop here in Australia.
They supplied the plane and a E Flite 480 outrunner motor & 20-25 amp E Flite speedy and 2200mha 3S 18C lipo. The manual recomends a 12x6 or 11x7 prop.
I tested the motor with a watt meter using the 11x7 prop and found at full throtle it was pulling 30amps with 250 watts.
I tried a 11x4.7 and got 25amps and 220 watts. Does the wattage measured on the ground equate to the same level when flying?
I then flew it and found it to be very sluggish in vertical climbs and I've been told to do hovers you need to able to excelerate pretty quickly from hovers to be able to do them properly.
After calculating the power to weight ratio I found its about 140 watts/pound and going by the charts I should have 200+ watts/pound.
Has anyone tried this plane, what was the setup?
Should I be looking at a higher wattage motor?
CJQ is offline
Old 12-18-2007, 04:01 AM
Mr. Baggins
Goofball
Mr. Baggins's Avatar
Which 480 is it? 1020 or 910 KV
Mr. Baggins is offline
Old 12-18-2007, 06:41 AM
CJQ
Motor Specs
Model EFLM1500
Kv 910
Continuous Current 20 amps
Max Burst Current 25 amps
CJQ is offline
Old 12-18-2007, 11:47 PM
Mr. Baggins
Goofball
There's your answer. The 1020 is the one you want with the 12x6E prop. I use both but on the 910 I use a APC 13x4E prop. I really like that setup myself. Give the 13x4E a try and see what you think.
Old 12-19-2007, 02:45 AM
CJQ
Thanks for the info Mr Baggins
CJQ is offline
Old 12-19-2007, 03:29 PM
bhatch21
Default Check your battery
CJQ, based on your testing, it looks like the voltage of your pack is sagging. You said with the 11x7 prop it was pulling 30amps and producing 250watts. That yields a voltage of 8.3v. That will probably damage the battery. Make sure your pack is fully charged. If that's not it, I wouldn't trust that C rating.
bhatch21 is offline
Old 12-19-2007, 03:40 PM
BuzzardBait
Landing Gear?????????
BuzzardBait's Avatar
Mr. Baggins answered you other Q's...
The answer to this is.. No.. and Yes.....
because you're moving foward in the air when flying, less load is placed on the motor at a given throttle position as the plane reaches whatever speed it would reach for that throttle position..
However.. In a however.. if it takes 3/4 throttle to hover, the load on the motor is going to pretty much be exactly what it is at 3/4 throttle on the bench.
Another thing that can make a difference between static testing and in the air is propellar choice. High pitch propellars can "stall-out" when on the bench.. this means that they are creating too much turbulence and not taking the bite out of the air that they should.... In THIS case.. your WOT on the bench may be less than WOT at 10KTS in the air when the propellar starts to get bite... With 3d planes.. its usually wiser to stay with a lower pitch, bigger diameter prop to aviod this problem since you will be trucking around at very low airspeeds a lot of the time. Hence the 13X4 Mr Baggins suggests!
BuzzardBait is offline
Old 12-20-2007, 03:12 AM
CJQ
Thanks for the info guys.
When I had the meter on doing a static test I kept an eye on the voltage and it didn't go below 10 amps.
I have since spoken to Model Filght here in Aust and they think there is somethink the matter with the motor or speedy as they have sold hundreds or these motor/speedy conbination and have had a couple with simular problems, so I sending it back and I'm going to replace it with the next size motor up which is 350Watt 30 amp 11Kv
CJQ is offline
jobu
04-01-2008 05:27 AM
RandolphNav
ParkFlyers
07-18-2007 07:59 AM
PatternFlyer
06-16-2007 12:16 PM
WRX Dave
Foamies
01-16-2007 11:12 PM
debhicks
New Product Announcements
11-07-2006 11:19 PM
Quick Reply: E-Flite Extra 260 wrong motor setup?
Page generated in 0.10414 seconds with 13 queries
