Forward looking video camera - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-26-2007, 07:39 PM
Sparky Paul
Sparky Paul's Avatar
Default Forward looking video camera
Looking along the line of flight with a Mustek video camera.. this is NOT recommended!
But notice how well the prop brake works!
http://www.rcgroups.com/forums/showt...87#post6805024
Sparky Paul is offline
Old 01-26-2007, 07:51 PM
JWilliams
heh, that's pretty bad. I wonder how long until somebody rigs up a cam to work in concert with the propeller so that its staggering its frames and does not take a frame when the prop is in front of it, similar to how WWI era machine guns shot through the prop's circle without blowing the propeller up.
JWilliams is offline
Old 01-26-2007, 08:50 PM
Sparky Paul
There's 9 prop blades in this image where the motor is running fastest..
That's 4-1/2 revolutions in 1/30th of a second.
It'd take a really good interrupter to get around that..
Old 01-26-2007, 09:09 PM
quailbird
quailbird's Avatar
The camera has good color though! Hee Hee!
quailbird is offline
Old 01-26-2007, 10:31 PM
aviatordave
aviatordave's Avatar
I'd like to use a hard brake so I dont hear that windmilling when I power off in my videos, but it would wreck my gearbox..so I live with it or get another motor....
nobody likes gearboxes anyways!
aviatordave is offline
Old 01-27-2007, 12:13 AM
Sparky Paul
That's an Eflite Outrunner 450. With an APC 10x3.8 and 3 cells, it has more than enough poop for the plane.
I put the camera in another one and flew it at the same place..
It shows the camera really oughta be looking down about 1/4 the vertical field of view to get more interesting stuff than just plain sky.. and the autoexposure works better when looking more at ground than sky.
ID:	22928   Click image for larger version
Old 01-27-2007, 01:09 AM
aviatordave
Sparky,
You should enter some pics of your planes for the WF calendar. You seem to have alot of nice ground and air shots.
http://www.wattflyer.com/forums/showthread.php?t=14885
besides, there isnt too many AP planes in there so far!
Dave
Old 01-27-2007, 02:30 AM
TeslaWinger
With video having 30 frames per second it could take a frame with a high speed shutter, wait a few hundred RPM and take the next but the tach interface and computer software would be a real fun programming project- for somebody else! Still wouldn't be able to lower the horizon angle without filling the frame with nose! Twins and pushers are easier- just nose mount them!
That's why I made a pod for my camera- but it would have to be very tall to get a low enough angle to keep the sky at the top quarter of the frame so it will expose for the ground better, yet still keep the nose outta the frame.
ID:	22949   Click image for larger version
TeslaWinger is offline
Old 01-27-2007, 04:59 PM
Sparky Paul
Pushers or twins will keep the prop out of the field of view without having to go to extreme configurations.
With the skinny video cameras, a plane could be built with a slimmish fuselage holding the camera looking forward, and it could fit one of the usual flat box type looking to the side, without the fuselage needing to be too wide when side looking is preferred..
Old 01-29-2007, 04:49 AM
Sparky Paul
The pusher plane, glider body, GL wing... then with the motor above the wing, tractor style,..
Kinda tippy nose wise taking off dirt..
Eflite 400, 9x4.7, 3C1100
Tonight it became a twin..
2x370 brushed, 6:1 gear, 11x4.7, 8x1000 ..
ID:	23089   Click image for larger version
ID:	23090   Click image for larger version
Old 01-29-2007, 05:19 AM
Flyer 1
Flying Is Living
Flyer 1's Avatar
The "Gentle Lady" was my very first sailplane - someone goaded me into building one to prove I could really "find and use" thermals, as I insisted I could with (at that time) several of my gassers.
Man, I loved that plane (glider). Where I live is a HUGE hill right in the middle of our local public swimming pool's park - it's about 150 feet high, just a BIG dome of dirt covered with grass.
When I wasn't using a hi-start, the Gentle Lady could do a passable job of slope-soaring using the generated by that hill.
Those were the days! You're giving me the urge to get another Gentle Lady and electrifly it.
Flyer
Flyer 1 is offline
Old 01-30-2007, 01:34 AM
Sparky Paul
Combined 3 videos.. one with the camera looking thru the prop, the second with the camera ahead of the prop, but looking straight ahead.. and the third with the camera ahead of the prop looking down about 15 degrees.
This keeps the bright sky from underexposing the detail on the ground.
http://www.rcgroups.com/forums/showthread.php?t=634361
Angler-Hi
Aerial Photography
24
01-05-2008 05:54 PM
Pconn5
Aerial Photography
9
07-23-2007 07:31 PM
aviatordave
Aerial Photography
56
12-24-2006 03:19 AM
supercub21
12-05-2006 12:21 AM
Kosh
Aerial Photography
06-06-2006 05:05 AM
Quick Reply: Forward looking video camera
Page generated in 0.11214 seconds with 22 queries
