ksol-Alpha Mig-15
Old 08-09-2005, 02:41 AM
ksol
Default ksol-Alpha Mig-15
I am starting an Alpha Mig-15. Has anyone built this model? Any suggestions will be appreciated.
ksol is offline
Old 08-09-2005, 11:11 PM
L454S
L454S's Avatar
Wink Alpha Mig 15
Make sure you scrape off all the paint in the wing root area on the fuse for the glue to hold. The stab incidence is negative, resulting in built in up elevator. Fudge the leading edge of the stab up about 1/16in. and you wont need any elevator trim. I used the Himax 2015-5400 with a Tanic 2150 3s and CC25. Flies great and takes off of the ground easily.
L454S is offline
Old 08-10-2005, 03:02 AM
ksol
Default ksol
Thanks for the info I will follow your suggestions. Do you take off from grass or a paved runway?
ksol is offline
Old 08-19-2005, 04:02 AM
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
I have one suggestion and that would be to glass the fuselage...these things are a hollow shell and no matter how careful you may be, it's going to go soft and mushy in no time. Using .5oz glass and thinned Zpoxy resin will not add any appreciable weight. They fly great but IMHO the price for the convenience in building is not worth it based on the lifespan of these things. Same for the TU-183 as well. OF course, this is MHO.
..bob
bobthenuke is offline
Old 08-20-2005, 01:19 AM
ksol
That is interesting. Do you use a brush for application?
ksol
ksol is offline
Old 08-20-2005, 05:36 PM
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
ksol,
If you're not familiar with fiberglassing techniques I'd get some help or let it go. Even reading instructions for the first time would best be practiced on a junker (there are instructions for glassing all over the web), not a nice new plane like your MIG.
Old 08-20-2005, 10:18 PM
ksol
ok I will do that.
ksol is offline
Old 09-13-2005, 03:15 AM
Son of Paleface
Ozzie Express Wiggy Pilot
Son of Paleface's Avatar
Question
..bob
Do you glass the inside , if so where.........
On the outside I guess along the bottom from the nose to the fuzz join over the plastic insert
Son of Paleface is offline
Old 09-13-2005, 06:51 PM
ksol
I have used a water based polycrylic spray (Minwax Polycrylic clear gloss protective spray). It does not eat the foam and gives protection .
Seems to work pretty good and it is clear and does not affect the aluminum color.
Ken Solomon
ksol is offline
Old 09-17-2005, 01:30 AM
mavdriver
Ken Solomon
ken no need for fiberglass just fly it is an awsome bird the way it is just fly it here are some pics of mine it rotates with out incidedent , don`t make any more work for yourself hope that helps
mavdriver is offline
Old 09-17-2005, 01:40 AM
mavdriver
ken one more thing reinforce the wings where the wings join the fuselage , by the way i added two hitec 55 servos for the aillerons one for each side , thats just me you can get away with one servo but i prefferd two
NUTS
Electric Ducted Fan Jets
07-30-2007 02:39 PM
ELECTROGLIDE
09-18-2006 11:57 PM
ELECTROGLIDE
08-26-2006 12:27 AM
vax6335
11
07-19-2006 12:13 PM
knighttwister
10-18-2005 02:52 AM
Quick Reply: ksol-Alpha Mig-15
Page generated in 0.12735 seconds with 13 queries
