spitfire
Old 08-18-2007, 05:48 PM
  #101
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Sounds good... I guess time will tell. Are the spars supposed to be pine?
brnyrbbl is offline
Old 08-18-2007, 05:54 PM
  #102
spitfire
Not the best
spitfire's Avatar
yes
spitfire is offline
Old 08-18-2007, 06:16 PM
  #103
spitfire
Not the best
spitfire's Avatar
well i got some more work done
ID:	38453   Click image for larger version
ID:	38454   Click image for larger version
spitfire is offline
Old 08-18-2007, 07:26 PM
  #104
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
Originally Posted by spitfire View Post
yes but win i click upload it just stops working:<
What resolution on the camera are you using....I use the lowest my camera will do...123K JPEG....when you click upload it can take a while...especially if you use a dial-up connection!!....you might just have to wait.
Woops....you already figured it out.........Looks good....fully sheeting it will make it really strong!!!
I have built kits thhat had split ribs before...though not common, it does work...and fully sheeting it will really lock it in place!!
Biplane Murphy is offline
Old 08-18-2007, 07:33 PM
  #105
efinkg
efinkg's Avatar
Looking good, but are you SURE the spars are supposed to be pine? I have never used pine on any model, including on my 1/6 Zero(lots of lite-ply instead though). Perhaps 1/32 sheeting would be better also, just to keep weight down, you probably want less than 18 oz. Last, welcome to the long-lost instructions... page 1: http://www.radio-control-flyer.com/s...tructions.html
page 2: http://www.radio-control-flyer.com/s...ionspage2.html
Oh don't worry, no need to thank me, its all for everyone's happiness.
efinkg is offline
Old 08-18-2007, 09:39 PM
  #106
spitfire
Not the best
spitfire's Avatar
yes i am sure, it says use pine. and here are some more pics
ID:	38458   Click image for larger version
ID:	38459   Click image for larger version
spitfire is offline
Old 08-19-2007, 06:58 AM
  #107
Wolfsbane
Wolfsbane's Avatar
Looking good!
Might get this one myself
Wolfsbane is offline
Old 08-19-2007, 05:03 PM
  #108
Lip84
Lip84's Avatar
I was curious watching this build. Do we want warbirds to have truly flat bottom airfoils? I was a little put off when I first saw this and it seems like its not the best airfoil for a warbird.
BTW...Looks good...keep it up. And since it is full sheeted the split spars should be fine...just get the CA in there good.
Lip84 is offline
Old 08-20-2007, 12:30 PM
  #109
Wolfsbane
Wolfsbane's Avatar
hmmm... Looking at the site you had for the plans and the plans themselves, I'd take a look again on the wing tips there spitfire... The wing tips should ne one piece from former w5 as far as I can see... just a heads up for you
Old 08-22-2007, 05:56 PM
  #110
spitfire
Not the best
spitfire's Avatar
i know its a little bit early but how should i do the cameo covering job
spitfire is offline
Old 08-22-2007, 05:58 PM
  #111
Biplane Murphy
airbrush would be easy......
Old 08-22-2007, 06:06 PM
  #112
spitfire
Not the best
spitfire's Avatar
how should i mask it off??
spitfire is offline
Old 08-22-2007, 06:37 PM
  #113
Biplane Murphy
Paper templates...tape...anything you think will work.....
Old 08-22-2007, 06:41 PM
  #114
Lip84
Lip84's Avatar
You can get cool coverage patterns by using a template and holding it a short distance from the surface to be painted. I think this is pretty common knowledge though.
Lip84 is offline
Old 09-06-2007, 05:54 PM
  #115
spitfire
Not the best
spitfire's Avatar
now he tells me
spitfire is offline
Old 09-06-2007, 05:55 PM
  #116
spitfire
Not the best
spitfire's Avatar
i don't know if i will ever get it finished at this rate
i really need some encouragement
spitfire is offline
Old 09-06-2007, 10:11 PM
  #117
Biplane Murphy
O.K. In a singing/ chanting voice......
"Go Spitfire...Go Spitfire.... you can do it....cut the balsa...glue the wingtip...It's your birthday......"
Old 09-07-2007, 04:21 PM
  #118
Tinman
The Hot dog man
Tinman's Avatar
You can doooo it!!!!!
Tinman is offline
Old 09-08-2007, 02:28 AM
  #119
Wolfsbane
Wolfsbane's Avatar
Spit.. don't rush through this.
A build like this you should go fairly slow and just get it right. You don't wanna get ahead of yourself and have to redo something again, trust me been there and done that
Besides, get it done right and you'll definetly enjoy the build more when you get her in the air.
Old 09-10-2007, 05:26 PM
  #120
spitfire
Not the best
spitfire's Avatar
ok... well i think i am going to have to start the wings over ... i will be able to do the fuse
spitfire is offline
Old 12-18-2008, 09:49 AM
  #121
fedrik
Hi,
Ya absolutely welcome. Give us much more information on your project.
fedrik is offline
Old 12-19-2008, 06:11 PM
  #122
TbigD
Not to burst your bubble , but this plane is going to be very heavy and will be a handfull to fly for even the best pilot , 30 in span and 400 watts , before you get too far , you might want to rethink this.....Dennis
TbigD is offline
Old 11-08-2009, 10:43 PM
  #123
spitfire
Not the best
spitfire's Avatar
wow... has it really been that long?
I have been doing alot in the past so ever long time... but I think I might start getting back on the project... the biggest problem is its not exactly easy to plop $$$ on the table for motors and lipos...
I wanted to go back to the site where I got the plans, but it looks like he took it down!!!!!
soooooooooooo...
now I need new plans... oh boy... this will be fun... (insert sarcasim here...)
so yeah, other than that, I have been doing great... I see a lot of new people here... and its kinda funny to see so many mods... I can just look at a single thread and see about five in a row... it kinda makes me wonder what the point is! but I know why we have so many here...
but anyways, to keep it on topic... I will probably locate some new plans, and I will try and check up on wattflyer now and then... at least more than I have
SPIT.
Last edited by spitfire; 11-08-2009 at 10:44 PM. Reason: fixed some poorly written text...
spitfire is offline
Old 11-09-2009, 04:00 PM
  #124
spitfire
Not the best
spitfire's Avatar
WOW... I just found them...
http://www.rcgroups.com/forums/showthread.php?t=1104298
its an rcgroups link (obviously)... but the plans are there, the one I need is the second one down... but there is also a pretty sweet looking 49" one... the one I am going to build is the 29"
I downloaded them... and I will not let it out of my sites again!
so yeah, I guess I will start building next time we can make a trip to the hobby stop!
spitfire is offline
Old 11-09-2009, 09:15 PM
  #125
spitfire
Not the best
spitfire's Avatar
does anyone think I outta start a new project thread for my spitfire project?
this one is rather old, and I don't think anyone seems like they are even looking at it anymore...
idk... I kinda want a fresh start with the whole thing...
spitfire is offline
Quick Reply: spitfire
Page generated in 0.11343 seconds with 19 queries
