EFlite Apprentice and T34 Mentor Battery Packs
Old 05-18-2011, 08:08 PM
cbatters
cbatters's Avatar
Default EFlite Apprentice and T34 Mentor Battery Packs
Both the Apprentice and Mentor ship with 3S3200 15C battery packs but they are very expensive and I would like to grab a few more packs.
Anyone using other brand packs with same specs but lower cost?
Model number /links appreciated.
Clint
cbatters is offline
Old 05-18-2011, 08:21 PM
Here you go:
http://www.hobbypartz.com/83p-3000mah-3s1p-111-20c.html
I really like these cells.
Old 05-18-2011, 10:27 PM
cbatters
cbatters's Avatar
Originally Posted by rcers View Post
Here you go:
Thanks for quick response.
How much hands on experience do we have on these? The Zippy and specifically the Rhino batteries earned their good reputation for quality (life cycles, durability and consistent performance over those cycles)
(Looking for batteries that are comparable to EFlite or ESky OEM batteries, not top shelf THunder Power batteries.)
Clint
cbatters is offline
Old 05-18-2011, 10:29 PM
I use the same brand of 1800, 2200 and 3000 packs with excellent results. I have about 8 months on the 1800's and 6 months on the 3000's. Zero issues from me.
At less than $16 per pack the risk is mighty low to be honest.
Old 05-18-2011, 10:56 PM
cbatters
cbatters's Avatar
Here you go:
Agreed - low risk. I'll take a look at the range of batteries and see if they have something for the Radian that takes a smaller 3S1300 pack.
I'll see if anyone has started a compatibility /longevity thread and if not I'll start one and get some baseline data.
Clint
cbatters is offline
Old 05-24-2011, 12:35 AM
cbatters
cbatters's Avatar
More info on batteries from HobbyPartz
http://site.hobbypartz.com/battery/batterytest.htm
What we need is data to compare these batteries with ParkZone.
Does anyone have any idea who manufactures the Parkzone batteries? My sense is that the Parkzone batteries are actualy pretty high quality.
cbatters is offline
Old 05-24-2011, 01:47 PM
constantCrash
prefectionist
constantCrash's Avatar
I use Turnigy packs: http://www.hobbyking.com/hobbyking/s...dProduct=15003
Or flightmax packs:
http://www.hobbyking.com/hobbyking/s...dProduct=16701
I've actually been using 4s 4000mah pack in my T-34, flys like a bat out of hell, but the motor gets hot so it needs a 10 min cooldown between packs.
constantCrash is offline
Old 05-24-2011, 02:22 PM
bthrel
bthrel's Avatar
I dont have any data, but a good buddy of mine thats a heavy duty pattern flyer has been having good results with SKY lipos ( available on the same site linked above). Based on his usage I purchased 3 several months ago and they seem to perform quite well in my birds.
Mine are the 3S2200 30C, and I'll proly buy some more if they hold up.
YMMV
Brian
bthrel is offline
Old 05-24-2011, 06:38 PM
cbatters
cbatters's Avatar
Or flightmax packs:
Are you running stock ESC and motor ? How long have you been running the hopped up battery?
Clint
cbatters is offline
Old 05-24-2011, 08:17 PM
constantCrash
prefectionist
Stock E-flite 25 motor, APC thin electric 12x8 prop, but I replaced the stock 40A with a E-flite 60Amp pro ESC. (neccessary for the 4S)
Here's some flights I recorded in my spreadsheet
Code:
Date         Time          Date          Plane Battery                      Flight Time Notes
5/31/2010 11:04:08	5/31/2010	T-34	Flightmax 4000(4S) 1	4:00:00	"17.9wh
56.4amp
14.2vm
830.5watt
1188mah"
5/31/2010 11:23:26	5/31/2010	T-34	Flightmax 4000(4S) 2	4:15:00	"17.9wh
58.57amp
14.34vm
862watt
1479mah"
5/31/2010 12:26:54	5/31/2010	T-34	Flightmax 4000(4S) 1	4:30:00	"27.3wh
59.32amp
14.08vm
879watt
1848mah"
5/31/2010 13:08:02	5/31/2010	T-34	E-flite 3200(3S) 1	6:00:00	"26.6wh
39.67amp
10.06vm
436watt
2533mah"
5/31/2010 13:22:29	5/31/2010	T-34	Flightmax 4000(4S) 2	4:30:00	"33.2wh
59.6amp
14.15vm
889watt
2270mah"
5/31/2010 13:50:37	5/31/2010	T-34	Rino 3700(3S) 1	6:10:00	"29.2wh
41.1amp
10.71vm
483watt
2620mah"
5/31/2010 14:19:29	5/31/2010	T-34	Flightmax 4000(4S) 1	4:04:00	"29.4wh
58.57amp
14.15vm
867watt
2003mah"
Old 05-24-2011, 08:31 PM
cbatters
cbatters's Avatar
Thx
cbatters is offline
Old 05-30-2011, 04:51 AM
cbatters
cbatters's Avatar
Bought a 3000 MAH. Blue Lipo pack from Hobbypartz and am impressed with how it performs compared to a stock eFlite 3200 pack. Same performance for less than half the price.
Clint
cbatters is offline
Page generated in 0.07799 seconds with 12 queries
