Blade MCX2 Gears Not Meshing
Old 05-16-2013, 01:24 AM
CoolBreeze
Default Blade MCX2 Gears Not Meshing
Today I was able to fly the heli for about 4-5 minutes - the heli lifted to almost the ceiling in my living room and I was able to fly the heli around the living room. Then the gears for the bottom blades stopped meshing together. The top blades spin just fine. But with the bottom rotor spinning slower than it should the heli doesn't get enough lift.
Any suggestions?
CoolBreeze is offline
Old 05-16-2013, 01:28 AM
Check the motor of the offending system is secure. Check the gear on the rotor shaft doesn't have a screw loose, causing it to slip out of place.
Old 11-26-2013, 10:47 PM
dontrinko
On mine the motors will slide up and down. Slide the motor until it meshes correctly. If it slides to easy put a drop of hot glue , rubber cement or something to hold it in place.
Don
dontrinko is offline
electrodude71
05-08-2013 02:43 AM
01-15-2012 01:48 AM
blade-msr
09-26-2011 06:06 PM
blade-msr
Beginners - Helis
09-26-2011 07:06 AM
calldaffer
General RC E-Heli Talk
03-29-2011 02:03 AM
Quick Reply: Blade MCX2 Gears Not Meshing
Page generated in 0.06197 seconds with 11 queries
