UM T-28 Maiden. - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
UM T-28 Maiden.
Old 03-14-2013, 01:43 AM
SW5-Flier
Default UM T-28 Maiden.
Hi!
I just now maidened my UM T-28! Here is pretty well how it went:
After sitting there still too nervous to launch, I finally hand launched it (No good place to really take off in a grass field .) and it went up waaay too much and stalled out. Took a look at it, and my CG was way off. Adjusted the CG, and tried again. Same thing happened this time. Not sure what happened there. Then, finally, I had a successful launch, and flight. I was surprised at how well it handled, even in the slight breeze we had. Landing went prefect, and had 2 more flights just like that one before my battery drained.
Now I guess I had a little question. It sort of "bobbed" up and down as it flew, any idea what could have caused this, or how to fix it?
SW5-Flier is offline
Old 03-14-2013, 02:53 AM
hoghead5150
you mentioned "slight breeze". even this will affect the um planes pretty well. mine would "bobble" around flying into the wind, but flying with the wind it was smooth. i think when i would fly into the wind the plane would climb and i would push the stick to try and keep the plane level, thus i was causing the bobble.
i've flown the um t-28 in around 10mph winds and its a handful. fun once you get confident enough to do it, scary as all get out if your new to flying!!
congrats on the maiden flight!!!!
hoghead5150 is offline
Old 03-14-2013, 02:58 AM
SW5-Flier
Thanks.
I guess it's just a little sensitive to the wind compared to my champ...I can usually pilot my champ in up to about 6 mph winds and still be able to keep it airborne and on a general flight path. I guess I could have thought and figured it out, just sort of used to my champ, I guess, so I wasn't expecting the bobbing effect so much.
Old 03-15-2013, 02:14 AM
SW5-Flier
Update: I flew it again today! However, I did have to wait the whole day for the wind to die down. I had a nice first flight, practicing keeping it nice and steady, and had a nice landing. Second flight was absolutely beautiful, I kept it very level and had some nice turns. Third flight was interesting... I ended up losing orientation of the plane (it was getting a bit dark outside.) and then cut the throttle, and promptly hit the branches of a tree, thank goodness it didn't get stuck, but just took a fall. The only damage was some paint chipped off the cowl and a *tiny* bit of crumpled foam in the same spot.
That was my flights today in a nutshell...
Old 03-15-2013, 03:03 AM
hoghead5150
lol, it seems that trees just love to eat planes!! i swear they will jump right out in front of a plane to get a bite.
Old 03-15-2013, 03:07 AM
SW5-Flier
I know right? Not the first time one of my planes had a run-in with a tree. My champ got a face full of branches once as well.
Old 03-15-2013, 04:47 AM
BroncoSquid
Workin on it...
BroncoSquid's Avatar
I hear you on that one. I fly at dusk when there is no wind most of the time also. I could see the plane easy enough, just couldn't tell exactly if it was coming at me or going away. Especially in turns. So I added (4) 3mm LEDs, 2 small resistors, and tapped directly into the wires from the batteries. Only reduced flight time by approx 45sec at full throttle.
BroncoSquid is offline
Old 03-15-2013, 10:09 AM
The 'bobbing' up and down sounds like it's maybe flying in a series of climbs, stalls and dives (looks like a roller-coaster?) that's often simply due to not being trimmed out properly, you may just need some downtrim?
Old 03-15-2013, 01:11 PM
SW5-Flier
Yeah, figured that out yesterday. I noticed when I came in for a landing it acted just a bit tail heavy, so I figured it had too much up trim on the elevator. Thanks for trying to help anyways!
Old 03-15-2013, 01:17 PM
SW5-Flier
Sounds like a nice idea. How much would a setup cost for something like that? I think I might try that. I almost always fly around 5-7 PM so it's usually getting a bit dark out.
Old 03-15-2013, 07:15 PM
BroncoSquid
Workin on it...
I think the small spool of 30ga. wire was the most expensive part. 12$ IIRC. 3mm LEDS were 1 or 2 bucks for a pack of 3. I got red, green, white, and blue. A small pack of 100 diffrent size resistors was like 5 bucks. You could do it with a basic soldering kit. I set it up on a breadboard to make sure it worked.
Oh, side note, tape a length of .060 CF rod down the center of both wings. Keeps the wings from cracking during rough landings and chance encounters with trees.
Old 03-18-2013, 12:56 PM
SW5-Flier
Sorry didn't respond earlier, I'm on vacation and I've been busy. Anyways, I really want to have one of those LED setups, but, I didn't think about having to use a soldering kit... Because, I don't have one. How much does a soldering kit cost? I don't want anything fancy just one that'll do the job. Thanks!
Timewarp
Scale E-Powered Aircraft
11-25-2012 07:56 PM
waterfire
07-30-2012 07:14 AM
Davethebluessinger
11-28-2011 04:55 AM
splash1MiG
10-16-2011 08:34 PM
motor12
Warbird Electrics
04-21-2011 03:04 AM
Quick Reply: UM T-28 Maiden.
Page generated in 0.12747 seconds with 16 queries
