Magnetic building board
Old 09-17-2014, 03:08 AM
Abuelo
Abuelo's Avatar
Default Magnetic building board
I decided I needed a better building surface than I had been using, a drafting board from high school. Got the idea of a magnetic one from the forum and tracked down the pieces.
The metal surface is from Home Depot, 24" x 36", for $9.34. I cut the plywood base from scrap Baltic birch I had, very slightly oversize, about 1/8", so there would not be any sharp metal edges. As the plywood was slightly warped knew i would need a base of some sort. I found at a Habitat for Humanities ReStore a surplus drawer, about 22" x 36" x 2" high, for $2.00.
I added two drawer interior supports so the plywood would have more contact, glued them all together with Titebond and used finishing nails to pull the plywood level. Once all was setup, nails countersunk and the plywood sanded, I used about half of a pint can of contact cement to attach the metal to the plywood.
The magnets are from Harbor Freight, the four red are welding magnets and provide right angle support and the dark gray ones are for general construction. The latter are 2 for 98Ę but right now are on sale at half price.
The ply and metal is larger than the drawer. I wanted an overhang so I would have a way could easily clamp to the surface. Typically, I clamp a metal yardstick down and build against it when I need something straight, like a wing. Right now I'm building the Murgatroid's wing there.
Photos attached. An easy and quick project with the total cost about $20.
Name:	Magmetic building board materials.JPG
ID:	177406   Click image for larger version
Name:	Magnetic board complete, with Murgatroid.JPG
Abuelo is offline
Old 09-17-2014, 04:54 AM
Brner
AMA16634
great idea and not very expensive to boot.....I like it...
Brner is offline
Old 09-18-2014, 09:03 PM
Abuelo
Abuelo's Avatar
Here is a photo of the board in use.
The plan is clamped down with waxed paper over and a metal yardstick serving as a hard straight edge for the wing. Magnets and clamps hold everything else.
The pop can shown has a concave base that works perfect for holding a small amount of glue or for mixing epoxy. Very handy and readily available.
Name:	Magnetic building board in use..JPG
Abuelo is offline
Old 09-18-2014, 09:34 PM
road king 97
old hat
road king 97's Avatar
I have always wanted a new magnet building table and soon i will build one . The harbor freight magnets look good so i will check them out . Thanks abuelo , joe
road king 97 is offline
Old 09-18-2014, 09:36 PM
Brner
AMA16634
I do believe I need to visit Home Depot today. My wifes in a good mood so 30-40 dollars isn't going to upset her much.....lol
And I already have an assortment of right angle magnets from HF and a good base to contact the sheet metal down to.
Need to pick up some of those domino shaped magnets and some contact adhesive while out and about also....
Don
Brner is offline
Old 09-18-2014, 09:59 PM
road king 97
old hat
I have a steel guy i use to supply my beams for the houses i build so i will have to get a sheet bigger than most but it wont be hard to find a large piece . The magnets were the hard part to get a deal on . joe
ID:	177434   Click image for larger version
Old 09-18-2014, 10:22 PM
If anyone is looking for high powered magnets, they are available. Not cheap though.
http://www.kjmagnetics.com/products.asp?cat=11
Also, the American Science and Surplus center has a whole selection of magnets. Here is one of them:
http://www.sciplus.com/p/BAR-MAGNETS_51248
Old 09-18-2014, 11:12 PM
Past President of PSSF
Joe,
When I saw the picture of you working on your plane, I realized, you are much younger and shorter than I would have guessed.
As long as we keep working on model airplanes, we never really grow up.
Wildflyer is offline
Old 09-19-2014, 12:04 AM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Keep in mind magnet prices from K&J are usually for a pack of 10 (or more) so their prices (for me) are extremely good and their service even better. I've been using them for the past few years and they absolutely ROCK!
I have one of the original Eldon J. Lind "Magic Magnet" building boards and wouldn't part with it for the world. I also have boxes of the magnets and accessory hold downs. I do think I need to hit Harbor Freight and grab some of those welding magnets listed in the OP post. They'll work quite well on my board.
Joe
Turbojoe is offline
Old 09-19-2014, 12:12 AM
road king 97
old hat
Originally Posted by Wildflyer View Post
Joe,
He is 11 now and trained to cut parts out and sand them There was a reason for starting him out young ,i cant afford a lazer cutter ! joe
Old 09-19-2014, 01:08 AM
I've got a hand full of Cobalt magnets from work that will lift some 500 pounds on a one inch thick steel block. Those things can really hurt you. Got one of my fingers mixed in with one, and it didn't stop bleeding for 8 hours.
Old 09-19-2014, 01:26 AM
Turbojoe
Turbojoe's Avatar
Ouch! Yeah, some of the magnets available now should maybe be listed as weapons!
Joe
Turbojoe is offline
Old 09-19-2014, 05:24 AM
Joe
Yeah, they make you sign a waiver before ordering this magnet that can lift 1000 pounds.
http://www.kjmagnetics.com/proddetai...d=BZX0Z0Y0-N52
Old 09-19-2014, 12:02 PM
Brner
AMA16634
Keep in mind magnet prices from K&J are usually for a pack of 10 (or more)......
Joe
Joe,
Where did you find this information on their website?
Don
Brner is offline
Old 09-19-2014, 04:20 PM
Turbojoe
Turbojoe's Avatar
Originally Posted by DEG View Post
Joe,
Don
http://www.kjmagnetics.com/products.asp?cat=10 This was the last page I ordered from. I probably should have said most of the smaller sizes were in 10 packs.
Joe
Turbojoe is offline
Old 09-19-2014, 05:13 PM
Brner
AMA16634
Thanks Joe.....makes a big difference in price....If you know off hand, what is the pulling power of the magnets you use?
Brner is offline
Old 09-19-2014, 05:30 PM
Turbojoe
Turbojoe's Avatar
http://www.kjmagnetics.com/proddetail.asp?prod=D403 is what I use for hatches. All the specs are on this page. I have yet to find these in an LHS for under $1.25 each.
I ordered a bunch of those tiny magnets a while back for my daughter. She made a really cool activity board for my grandson with them.
Joe
Turbojoe is offline
Old 09-19-2014, 06:53 PM
Joe
FYI, just be aware that some small kids have swallowed those tiny magnets. Two of them can result in emergency surgery
Old 09-19-2014, 07:14 PM
Turbojoe
Turbojoe's Avatar
My daughter is not a typical parent. When she has activities with her son she is actually THERE with him. She doesn't toss him a toy and say go away while I watch TV. I wish I had taken pictures of what she made for him. The magnets are truly captive. He's almost 4 now and smarter than 99% of the college kids I deal with on a daily basis. He knows better than to ingest non food items. Sometimes I wonder about these kids on campus......
Joe
Turbojoe is offline
Old 09-19-2014, 07:25 PM
road king 97
old hat
I had saved this site long ago but i have a couple more saved also .http://www.easybuiltmodels.com/b04.htm and this one too .http://www.magnetsource.com/airfieldmodels/ As far as the kids eating stuff ! Mine are all grown and gone only the 11 year old home still and its peace and quite here except for my dogs barking , lol joe
Old 01-02-2019, 11:53 PM
Turbojoe
Turbojoe's Avatar
Bringing back an OLD thread. I still LOVE my Eldon J. Lind magnetic building board. The magnets however leave a LOT to be desired. The two side plates on every one of them, even the new ones I bought from Tower Hobbies before they were discontinued are poorly glued. Not a single one is square. I'd like to throw them all in the trash and have a fixture adapter that uses neodymium magnets. My daughter bought a 3D printer and it stays at my house. I'm doing my best to learn CAD so I can produce R/C related items in addition to what she wants. I'm having little luck designing parts so far. Just wondering if anyone has seen or maybe even designed a 3D printed neodymium replacement adapter for the garbage magnets that are supplied with the E.J. Lind board.
Joe
Turbojoe is offline
Old 01-03-2019, 12:34 AM
Joe
Check out tinkercad on the internet. This is a fairly easy to use CAD program for 3D printers, and its FREE! (I'm also a beginner with 3D printing, and am currently printing a faceplate for my BattIR project listed in RCGroups under DIY Electronics. That is a complex panel that holds an LCD display, Arduino Nano, couple of switches, supports for power resistors and battery holder. Next, check out Ideamaker, another free program that takes the Tinktercad files, and translates it to the files used by your 3D printer.
Last, check out this web page for a magnet supplier that carries just about anything you might need for your project.
https://www.kjmagnetics.com/neomaginfo.asp
https://www.kjmagnetics.com/products.asp?cat=1
Old 01-03-2019, 12:47 AM
Turbojoe
Turbojoe's Avatar
I started playing with Tinkercad yesterday. Minimal success so far but will hopefully improve soon. I've ordered from KJ Magnetics many times in the past and they rock! I'm getting good at 3D printing. Just hoping someone has already created the neodymium adapters I'm looking for.
Joe
Turbojoe is offline
Stevephoon
09-16-2014 12:59 AM
Wrongway-Feldman
19
05-14-2014 08:00 AM
07-25-2013 08:33 AM
Mysterious
3D Flying
05-16-2013 01:08 AM
Murocflyer
11-04-2012 10:35 AM
Quick Reply: Magnetic building board
Page generated in 0.21198 seconds with 20 queries
