Slow Stick ESC & Battery - Page 5 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-22-2009, 02:38 PM
  #101
PaperAirplane
Subscribed...
PaperAirplane's Avatar
Originally Posted by Sir Raleigh View Post
You should be able to find a kit of these small screwdrivers (called Jeweler's screwdrivers) at Radio Shack. They come in a little plastic case and consist of about 4 - 5 each of flat blade and "X" point (or Phillips head) types. Shouldn't cost more than a couple of dollars.
Bill
Originally Posted by Gofer303 View Post
Try radio shack they have some mighty small screwdriver sets phillips and straight. They had the one that would fit the Walkera 4#3B rotor blade attachment and that is almost microscopic !!!!!
Thanks guys. Ill go to RadioShack eventually, for now I am using a screwdriver designed to repair eyeglassed.
PA
PaperAirplane is offline
Old 12-22-2009, 05:27 PM
  #102
Sir Raleigh
One thing I've found about those "Jeweler's Screwdrivers" is that the real cheap ones are made in China and the quality isn't all that great. The tips twist, break, and the "X" point ones wear down quickly and become useless.
However, I found this one (pictured) at my local hardware store which is a very fine quality with 4 interchangeable tips. Cost was around $3.50, I think, and well worth it.
Bill
Sir Raleigh is offline
Old 12-22-2009, 06:16 PM
  #103
PaperAirplane
Subscribed...
Bill
OK, Ill be sure to consider that.
I hooked up the servos. They have good throws when they are at the second-closest hole to the surface.
Whats wierd is these servos started randomly spazzing, without any input at all from me. At first I was hearing a bit of a grinding noise for, like, 2 seconds after the servos returned to neutral, but now they just spazz. Does anyone know what is causing this. I have no flying fields near me that may be interfiering.
PA
Old 12-22-2009, 08:54 PM
  #104
philipa_240sx
A little bit of 'coasting' is normal sometimes. Anything more and it could be a control surface or linkage is binding up. Do you have pictures?
philipa_240sx is offline
Old 12-22-2009, 09:29 PM
  #105
mumblinaviator
R/C Work and Play
mumblinaviator's Avatar
in my experience, the "spazzing" has always been caused by the wrong channel selected on my TX, or not turning my tx on at all.
mumblinaviator is offline
Old 12-22-2009, 10:02 PM
  #106
philipa_240sx
Good point. I have never experienced FM systems so I am not familiar with those sort of problems.
With my Spektrum RX's, all of the channels (except throttle) keep their last commanded position when the TX is turned off. Even when the TX is on, the only time I get servo twitching is a bound up control surface... or in one case a bad servo.
Old 12-23-2009, 12:23 AM
  #107
PaperAirplane
Subscribed...
Can I upload a video, without youtube?
EDIT: Apparently not. I will take photos.
Old 12-23-2009, 12:38 AM
  #108
PaperAirplane
Subscribed...
The pictures dissapeared.
EDIT:
Oh there they are again after I just made the next post.
Name:	Servos spazzing 003.jpg
ID:	116311   Click image for larger version
Name:	Servos spazzing 004.jpg
ID:	116312   Click image for larger version
Name:	Servos spazzing 005.jpg
ID:	116313   Click image for larger version
Name:	Servos spazzing 006.jpg
ID:	116314   Click image for larger version
Name:	Servos spazzing 007.jpg
Name:	Servos spazzing 008.jpg
Old 12-23-2009, 12:45 AM
  #109
PaperAirplane
Subscribed...
OK. The first pic is the servos in normal position with everything off.
The second pic is the linkages, still no spazzing.
The rest are the "suicidal" looking servos. They seem to twist as far as they possibly can.
ID:	116317   Click image for larger version
ID:	116318   Click image for larger version
ID:	116319   Click image for larger version
ID:	116320   Click image for larger version
Old 12-23-2009, 02:36 AM
  #110
philipa_240sx
Hmmmm.....
Did you rotate the servo arms by hand with the power off to 'center' them?
Old 12-23-2009, 04:35 AM
  #111
PaperAirplane
Subscribed...
I think I may have pushed the control suface up, and that may have happened. Would that have destroyed the servo?
Old 12-23-2009, 12:32 PM
  #112
philipa_240sx
If you force a servo hard enough you can strip the gears.
Personally, I would disconnect the linkage, remove the servo's from the plane and test them. You can simply rest them on a table top or something. If they still behave erratically then I would start looking at your connections, the RX and perhaps try a different servo.
Old 12-23-2009, 03:11 PM
  #113
PaperAirplane
Subscribed...
Ok, will try that. I dont have more servos, so I may have to order another.
Old 12-23-2009, 07:39 PM
  #114
PaperAirplane
Subscribed...
It seems that the problem was that my tx battery was very low. Is this possible?
No spazzing now that I have charged it.
EDIT:
I recieved the motor, battery, ESC, props, prop saver, and connectors Wednesday. HURC supplied it in perfect condition.
Old 12-28-2009, 03:40 PM
  #115
PaperAirplane
Subscribed...
So, is it possible that the servos were spazzing because of the low tx battery?
Looking for an answer
Old 12-28-2009, 04:10 PM
  #116
mumblinaviator
R/C Work and Play
Similar to what I posted awhile ago.... Low battery in the TX would be very similar to no TX at all. Plus, if you charged the battery and the spazzing stopped, you've already pin pointed the issue.
So go install your gear and have some fun!
praztek
10-05-2008 07:25 PM
Slowdoc
09-10-2006 02:38 AM
barrypfi
08-18-2006 05:10 PM
Heliguy12187
ParkFlyers
03-14-2006 05:11 AM
Armound
09-10-2005 09:55 PM
Quick Reply: Slow Stick ESC & Battery
Page generated in 0.13076 seconds with 26 queries
