Brushless for HobbyZone Super Cub?
Old 11-23-2006, 08:07 PM
aeromite
Figure 9 Specialist
aeromite's Avatar
Default Brushless for HobbyZone Super Cub?
I'm ready to go brushless on my Super Cub. I bought a "kit" by getting all of the parts for this great plane. Has anyone already converted to brusless? Can anyone recommend the best outrunner to install in this plane?
Aeromite
aeromite is offline
Old 11-23-2006, 08:34 PM
Crash Test Dummy
Crash Test Dummy's Avatar
I'll bet a E-Flight Park 380 or Park 400 outrunner would be a great set up. I don't recall anybody converting theres to BL, you might be the 1st!!!
CTD
Crash Test Dummy is offline
Old 11-24-2006, 04:43 PM
aeromite
Figure 9 Specialist
aeromite's Avatar
CTD
Great! Never really wanted to be the first - LOL! I will be using my new DX6 radio in what seems like a really nice plane from all reports I've read and seen. Thanks for the suggested power plants!
aeromite is offline
Old 01-24-2007, 03:31 AM
CubPhoon
I have modified my SC with Typhoon ailerons, E-Flight 450 Outrunner (moving to a 480 soon), and 25 amp speed controller. 7 watts of power for every once of weight will provide a nice fast plane.
CubPhoon is offline
Old 01-24-2007, 03:01 PM
CitaFly
Curious about your aileron setup - can you post some pics??
CitaFly is offline
Old 01-25-2007, 04:25 AM
CubPhoon
I can get some pics up this weekend - Gotta find my camera.
CubPhoon is offline
Old 01-26-2007, 04:45 PM
Loopy
Aeromite
Here is a video of a super cub after brushless convertion. He might have some suggestions.
http://www.youtube.com/watch?v=ye40CLpIGVo
Loopy is offline
Old 03-07-2007, 06:30 AM
SassyDave
Did you ever get any pics of your motor setup?
SassyDave is offline
Old 03-08-2007, 05:06 PM
WJCJR
Default My motor mount.
Go see the topic above titled Control Trouble After Mod. In the post I have pictures of my mount and a couple helpful links to some very useful information.
Wayne
WJCJR is offline
Old 03-10-2007, 06:19 AM
WJCJR
Default 450 Ourunner Mount
Here's the pictures of my motor mount.
First real flight was today. WOW this is a great set-up for the Super Cub. With the current thrust angles displayed oin the photos the plane flies straight as an arrow with all control surfaces trimmed flat and straight.
Check out this post, detailed are some COG troubles I ran into after removing the weighty stock equipment. http://www.wattflyer.com/forums/showthread.php?t=16919
Any questions please shoot and do let us know what you decide to go with in the end.
Wayne
ID:	25922   Click image for larger version
WJCJR is offline
Old 03-12-2007, 03:34 AM
ORD2FRA
WJCJR: PM Sent. Also how was the servo conversion? I'd like to see a pic of that, either yours or another's. How hard is it to do? Do the old ones rip out pretty easily?
I am 90% sure I am converting my SC to Brushless this week, with a Spektrum DX6 and Phoenix 25 ESC. Nice way to blow $300 and an evening! (Still cheaper than a new plane though!)
ORD2FRA is offline
Old 03-12-2007, 04:37 AM
SassyDave
Does anyone know of a less expensive alternative to the EFlite 450 brushless motor that provides the same kind of power?
--Dave
Old 03-12-2007, 05:01 AM
The Bandit
--Dave
My brother installed a $28 welgard in his...it flew equal to the other cub with a eflite 450. But we're getting away from Welgard, the shaft is made of really weak metal. He's on his third shaft. I would go with Himaxx...just a little cheaper than eflite, but one hell of a motor. I hear a lot of people using BP brand motors and seem to like it.
The Bandit is offline
Old 03-12-2007, 03:37 PM
CitaFly
--Dave
You could try a Scorpion - a little cheaper but not cheaply built. My review of the 2215-22 here:
http://www.ampaviators.com/index.php...d=27&Itemid=27
CitaFly is offline
Old 03-12-2007, 03:48 PM
CitaFly
Here's a pic of mine using two Spektrum S75s - I glued one piece of 1/16" plywood aft and the second piece forward is just a snug fit - this way you can easily pull the servos if you have to.
I led the servo wires aft - I have the receiver in the aft body compartment, leaving the battery compartment uncluttered.
CitaFly is offline
Old 03-14-2007, 04:30 AM
ORD2FRA
I went to the LHS for a BL motor setup... they were out of the Park 450s. I got a Hacker A20-20L. Big mistake. I get home and see they are for 15-18 ounce aircraft. Our Super Cub is 26-28 ounces.
Luckily I can return it and get a Park 480. I want some strong power and the ability to use 10x6 to 10x8 props. This, and the Phoenix 25 ESC will provide the punch I'm looking for. Radio is a DX6.
ORD2FRA is offline
Old 03-14-2007, 03:54 PM
CitaFly
With the 480, you could go to 11x8 - the recommended props range from 10" to 12"; an 11x8 is going to give you plenty of punch.
CitaFly is offline
Old 03-14-2007, 09:34 PM
ORD2FRA
Okay I got realistic and got a Hacker A20-26M, the recommended one on PeakEff-Pick A Motor. It'll still be about 113 watts/pound, which will still provide some good punch for the Super Cub. It's a bit more power than the Park 450.
Will use a stick mount and a 9x6 APC prop.
ORD2FRA is offline
Old 03-15-2007, 01:52 AM
WJCJR
Default Nice
With the 450 and the 9.6V 1500 Elites I get tons of punch.
If you are getting more power with that motor choice you will have plenty to spare. As a matter of fact, I rarely go over 50-60% throttle otherwise the plane eats up territory quickly and a three soccer ball field sized area goes by awfully quickly.
Do you have experience with the Phoenix 25? I am impressed one can reinvent the wheel with all the features this thing offers.
Get everything hooked up and let us know.
Wayne
WJCJR is offline
Old 03-17-2007, 10:02 PM
ORD2FRA
Here are some pics of my conversion...
  • Hacker A20-26M
  • Spektrum DX6
  • PHX 25 ESC
  • 9x6 electric prop
ID:	26348   Click image for larger version
ID:	26349   Click image for larger version
ORD2FRA is offline
Old 03-18-2007, 02:40 AM
SassyDave
  • Hacker A20-26M
  • Spektrum DX6
  • PHX 25 ESC
  • 9x6 electric prop
How durable is the stick mount? Have you had any hard nose-ins?
Old 03-18-2007, 06:33 AM
ORD2FRA
No nose-ins, at worst a ground loop. I'd rather cartwheel a wingtip than nose in. I'm confident enough that I can keep the nose off the ground at all times! If it does break someday, I have about 26" of wood left to make a new one, and a 1/4" drill bit works fine for that.
ORD2FRA is offline
Old 03-18-2007, 03:28 PM
simibill
General Factotum
simibill's Avatar
  • Hacker A20-26M
  • Spektrum DX6
  • PHX 25 ESC
  • 9x6 electric prop
Man that's a wicked amount of thrust offset.
simibill is offline
Old 03-19-2007, 12:09 AM
ORD2FRA
I got some onboard video of the brushless:
http://www.youtube.com/watch?v=WFvnpfYEfb0
Flies great now, very quiet. Thrust offset not an issue, in fact I needed to trim in some right rudder to keep it straight.
The only downside to brushless is what caused me to crash on the fifth flight today: I can't hear it! I had flown about 7-8 minutes (including the video) on this particular pack, and I didn't her the LVC (low voltage cutoff). It was so quiet that I thought I still had power. Well, I tip stalled and it hit nose first into the ground. It broke the motor mount and cowl, but that was all. Stick mount still intact. The stick is 2/3 inside the airplane, a good 4-5 inches behind the firewall.
Also took off some weight, now at 2 oz. total noseweight and that seems to fly just fine. I need to get a timer now so that I don't end up low and without power again.
ORD2FRA is offline
Old 03-19-2007, 03:27 AM
SassyDave
snip...
That is an awesome video! Way to go! Are you flying the Elite 1500mah pack from CheapBatteryPacks.com or a 3S lipo?
With all that power, I bet ailerons would be a blast to fly. Judging from the snappiness of the on-board video, I bet it'd fly great!
--Dave
Quick Reply: Brushless for HobbyZone Super Cub?
Page generated in 0.11227 seconds with 19 queries
