Futaba 7CHP?
Old 11-17-2007, 11:16 PM
tarzan13
tarzan13
Question Futaba 7CHP?
I want to buy a &chp radio for my esky belt cp.
Do I need to buy a receiver or will the esky do for now?
And do I need to buy digital servo to use the sub trim?
thanks for reply.
tarzan13 is offline
Old 11-17-2007, 11:35 PM
pilotpete2
Pilotpete2
pilotpete2's Avatar
Hi Tarzan,
With questions regarding radios in particular, it really helps to know where in the world or er- jungle you are
If you are in North America and are on 72Mhz, then there is the shift issue to consider, Futaba uses negative shift PPM/FM, I have no idea what Esky uses, but to use a Futaba transmitter with that receiver it must be negative shift.
What kind of servo you use has nothing to do with being able to use features on the transmitter, the only difference is in precision and ability to hold position more accurately under flight loads.
Good luck,
Pete
pilotpete2 is offline
Old 11-18-2007, 12:36 AM
tarzan13
tarzan13
I`m in the jungles of north-america.Lol!
and using the 72khz.
but Tarzan dont know much about radio!
tarzan13 is offline
Old 11-18-2007, 03:16 AM
tarzan13
tarzan13
i just read that esky receiver (ek2-0420a) is fm/ppm receiver compatible with futaba,kyosh,jr.
so it should work right?
tarzan13 is offline
Old 11-18-2007, 09:44 PM
pilotpete2
Pilotpete2
pilotpete2's Avatar
You should be good to go then, you just have to make sure transmitter and receiver are on the same channel.
Good luck,
Pete
restlessworker
E-Flite Helicopters
12-15-2007 04:21 AM
pilotwi
E-Flite Helicopters
08-05-2007 01:03 AM
Gary Hoorn
01-07-2007 11:25 PM
Gary Hoorn
07-06-2006 10:05 PM
ptremb
06-15-2006 03:15 AM
Quick Reply: Futaba 7CHP?
Page generated in 0.10768 seconds with 13 queries
