How to remove landing from retract body - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-10-2018, 11:22 PM
Jack_K
Jack_K's Avatar
Default How to remove landing from retract body
On a TopRC FW-190? The landing gear struts are bent slightly so the wheels won't retract into the wing.
How do I remove the landing gear from the retract body?
Jack
Jack_K is offline
Old 08-11-2018, 04:19 AM
Most retracts have grub screws into the sides of the trunnion (the bit that rotates). To get at them - you need to remove the whole gear from its mount so you have access to both sides ...
With most - you will see a brass insert in each side ... its the pivot ... a 1.5mm hex driver inserted in will find the grub screw deep inside. You do not have to unscrew and remove ... but unscrew enough to clear the flat on the landing leg.
Old 08-11-2018, 04:26 PM
Jack_K
Jack_K's Avatar
Thanks Nigel. That clearly explains it.
Jack
Jack_K is offline
Old 08-12-2018, 04:38 AM
Jack
Hope it works !!
Crash and Safety Forum
2155
02-09-2019 09:50 AM
05-31-2018 02:32 PM
brianfp_400
04-22-2012 02:52 PM
hayofstacks
03-05-2012 12:07 AM
Thewyzardofdogz
E-Flite Helicopters
03-19-2011 06:52 AM
Quick Reply: How to remove landing from retract body
Page generated in 0.05143 seconds with 15 queries
