My first Lipo fire - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
My first Lipo fire
Old 03-14-2007, 09:18 PM
Solid Hit
Just call me ... Bill
Solid Hit's Avatar
Default My first Lipo fire
I was out in the workshop getting a plane ready to ship off to Grasshopper and while I was out there I figured I'd charge up the little lipo I use to check servos and motor direction when building a plane.
It was a small 3c lipo whose ratings were worn out and that I thought I remembered being 750. I hooked it up to the Polly Four and set it to 750 and proceeded to box the Sportster. I guess I was getting too comfortable with lipos so I didn't take the normal precautions and just had it on a plastic mat on the bench instead of the ammo box I use.
Well, it it must have been a 350 not a 750 because about 1/2 hour into the charge it exploded in a ball of fire! I almost wet my pants!!! Taught me a lesson I won't soon forget.
Solid Hit is offline
Old 03-14-2007, 10:39 PM
PerlAddict
PerlAddict's Avatar
You might want to buy some of these.
PerlAddict is offline
Old 03-14-2007, 10:43 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Can you get them in asbestos?
Grasshopper is offline
Old 03-14-2007, 11:14 PM
Yeowwww! Hope there wasn't too much damage to the bench!
Don Sims is online now
Old 03-14-2007, 11:57 PM
Solid Hit
Solid Hit's Avatar
I got real lucky Don, I was there when it happened and was able to get it outside and also that it was a small battery. I was really suprised at how big and intense it was for such a small battery.
Old 03-15-2007, 12:07 AM
Glad to hear that Solid. I charge mine out in the barn inside of cinder blocks on a sand floor. I hang them off the end of the trailer at the field, I need to get an ammo box like you have!
Old 03-15-2007, 12:39 AM
skiman762
FFFC
skiman762's Avatar
Hey Don do you mean
Death from electrics
can say I've never had a jug a slime juice explode
skiman762 is offline
Old 03-15-2007, 02:12 AM
come to think of it, I don't recall seeing a slimer catch fire... good point ski!
Old 03-15-2007, 03:10 AM
Solid Hit
Solid Hit's Avatar
But that's only because I'm not flying them anymore.
Old 03-15-2007, 03:55 AM
Grasshopper
Saw a guy's gas powerd plane catch fire at the field one day. His first thought was to stomp it out. That didn't work very well.
Old 03-15-2007, 07:52 AM
Boomerang
Boomerang's Avatar
I also fly turbines. Fire? We learn to live with it! John.
Boomerang is offline
Old 03-15-2007, 01:31 PM
skiman762
FFFC
skiman762's Avatar
Well in all fairness can't blame the battery for that one
Just glad you were there to catch it and hadn't left it there on it's own
Old 03-15-2007, 02:10 PM
Matt Kirsch
Matt Kirsch's Avatar
Well, it wasn't necessarily a 350. You were charging with an Electrifly PolyCharge 4? That's a non-balancing charger. If the cells were out of balance by enough, the overcharged cell would catch fire at some point.
IMHO I really don't think your charge rate had much, if anything, to do with the fire. The pack was a 3S. The charger is only capable of charging up to 3S. Once the pack hit 12.6V, the charger should have automatically ramped the current down to maintain 12.6V until the pack was fully charged.
It is possible to charge LiPolys at more than 1C, if the charger has a 100% reliable way of detecting cell count, and never applies more than 4.2V per cell to the pack. Both FMA chargers advertise >1C capability, for example.
You still get the best capacity and performance at 1C, though, and you never know what's going to happen if you push the envelope on charging systems designed to deal with 1C. For example, >1C on an Astro 109 has been known to cause it to misread the cell count and overcharge packs!
In this case, the charger was maxxed out. It should not be able to apply more than 12.6V to ANY pack at ANY charge rate. Charging a 3S pack, you should have been safe. Nope, the pack had to have been out of balance, IMHO.
Matt Kirsch is offline
Old 03-15-2007, 02:46 PM
Solid Hit
Solid Hit's Avatar
Thanks Matt, that makes a lot of sense. I really need to balance my packs better. The Polly Four is a great unit since I usually fly several planes in a day and the ability to charge 4 packs at a time is a big help but I haven't been very vigilant about balancing.
Old 03-16-2007, 07:44 AM
Tailspin Ken
Tailspin Ken's Avatar
It may not be a total loss. I think you can epoxy it back together.
Glad that the incident was not any more serious than it was.
Ken
Tailspin Ken is offline
Old 03-16-2007, 09:05 AM
ragbag
Sometimes we bend the rules and get away with it. It's usualy when we bend more than one that it gets nasty.
The good thing is this thread will die on the vine.
The ones with all the damge will be reposted all over the web, giving the natsayer's somemore fodder for the grist mill.
Glad it came out good for him.
ragbag is offline
Old 03-16-2007, 03:29 PM
Matt Kirsch
Hopefully it will at least stand as a good example as to why balancing your packs, at least occasionally, is so important.
Old 03-16-2007, 03:43 PM
CitaFly
Has this been documented?
CitaFly is offline
Old 03-16-2007, 07:12 PM
JWilliams
Spectacular. It totally eradicated that pack. I've seen some burned packs that look like they burned but yours really looked like it went nuclear.
Glad nothing else got damaged
JWilliams is offline
Old 04-11-2007, 02:54 AM
ElectricFlyGuy
Banned Permanently
Talking New set of BRIEFS!
Hahahahahahaha Good one!!!!!!!!!!
ElectricFlyGuy is offline
orionRider
Batteries & Chargers
17
07-05-2007 05:29 PM
Solid Hit
05-23-2007 08:32 PM
skiman762
21
04-23-2007 04:24 PM
frugalflyer
35
12-18-2005 12:30 AM
hoppy
68
10-30-2005 11:33 PM
Quick Reply: My first Lipo fire
Page generated in 0.08882 seconds with 15 queries
