Sapac T34 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Sapac T34
Old 04-02-2007, 07:51 PM
Spiderrr
Default Sapac T34
Hi, does anybody have experience with this http://www.sapac.com.cn/prodshowe.as...90231&action=2 airplane? Thanks a lot
Spiderrr is offline
Old 04-02-2007, 09:47 PM
newjak
AMA Park Pilot Partner
newjak's Avatar
I am the somewhat proud owner of this plane. Ask your question
newjak is offline
Old 04-02-2007, 10:47 PM
Waterbird
I bought this model from Raidentech as an RTF for $99 -- see http://www.raidentech.com/tme4elrareco.html -- I confess I had pretty low expectations -- given the low price. But it's an INCREDIBLY good flyer!
In fact, it so impressed my most experienced RC buddy that he bought one! (He flew the real T-34 back in military years and was nostalgic.)
Now, I will confess -- I didn't even TRY to fly mine with the stock power system. It might be OK that way, but it looked so neat, I wanted to make it fly really well. So I replaced the stock brushed motor with a $19 brushless motor from here: http://www.hobby-lobby.com/brushless-skatty.htm -- that meant I had to replace the brushed controller -- but I found one for $10: https://www.unitedhobbies.com/UNITED...?idProduct=656
My battery is an 800 mah, 3-cell lipo -- which I moved forward (for balance) to right in back of the front wheel (cut a little compartment for it.
Configured like this, this little plane is a fantastic, docile flier, with a soft, straight ahead stall and it floats in gently to a nice soft landing on its tricycle gear.
Given the fact that I didn't use the motor, the ESC, the battery, charger and transmitter supplied in the RTF deal, I should have bought the $40 ARF -- see http://www.raidentech.com/4chtmerareco.html
Waterbird is offline
Old 04-03-2007, 10:12 AM
Spiderrr
Thanks for your experience once again
Spiderrr is offline
Old 04-04-2007, 01:37 PM
Leo L
Although I don't have the T34, one of the flyers at my field has one. It flew OK with the stock set-up, but like Waterbird, he replaced the stock motor with a small brushless and uses a 1000mah LiPo. The plane now flies really well. You don't indicate your experience level, but if you are a beginner, this is not the plane for you. Like all low wing aileron controlled planes this plane needs to be controlled at all times and is not self correcting. However, its a very good selection for an intermediate level flyer.
Leo L is offline
Old 04-04-2007, 05:06 PM
newjak
newjak's Avatar
Sorry for the slight delay in responding to your PM. I purchased this model in the RTF package which included the 290 motor. This motor will give you modest performance. It flies OK , but I had to add 1 oz in order to balance. The manual makes no mention of CG. I have mine set at aprox. 3" from the leading edge along the fusalage. Once you get the CG to where you are happy it will fly mild aerobatics like loops and rolls and inverted flight. Keep the throws low at first until you get used to the model. Landings are slow and easy. I like to land dead stick and it handles it nicely. Hope this helps.
BTW- DO NOT fly is winds over 8 mph ass it does not handle it well this should be your calm day flyer
newjak is offline
CaptainCub
Electric Ducted Fan Jets
13
05-17-2009 04:33 AM
dditch66
08-20-2008 02:59 PM
raptor-9
04-07-2007 10:02 PM
car1ce
12-09-2006 06:03 PM
Quick Reply: Sapac T34
Page generated in 0.09335 seconds with 13 queries
