Nieuport 28 ARF - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Nieuport 28 ARF
Old 06-26-2007, 09:26 PM
simibill
General Factotum
simibill's Avatar
Default Nieuport 28 ARF
I just bought one of these for $85 + S/H. It's a pretty neat model, built up balsa and plywood with chinese monocoat covering. I haven't decided on a motor for it yet, maybe a 400XT. The instructions consist of 15 pictures, no other info. French red, white, and blue stripes on rudder and top wing are the only markings.
http://www.rcuniverse.com/market/item.cfm?itemId=297582
simibill is offline
Old 06-30-2007, 05:28 PM
WWI Ace
triplane test pilot
WWI Ace's Avatar
Cool simibill let us know how it flies!!! Steve.
WWI Ace is offline
Old 06-30-2007, 06:03 PM
Tinman
The Hot dog man
Tinman's Avatar
Nice looking plane Bill. Keep us upated.
Tinman is offline
Old 08-17-2007, 06:45 PM
RBean
Default Neiuport ARF
When I saw the Nieuport 28 ARF ad I knew I had to have one. I think it is the best looking plane to come out of the "Great War". I ordered the package with outrunner motor, ESC and servos from Maxford USA. The plane is all wood balsa and light ply. The kit goes together well with no assembly problems. However the instructions are a series of photos and are essentially wouthless. One who has put together a few ARFs will have no problems. However, lacking was a balance point and control throws.
As with most WWI rotory engine models, one has to get all the weight as for forward as possible. I used a three cell lipo 11.1 v. 1350 mAh, placed as for forward as possible with the ESC also as for forward as possible but still had to add a bit of weight to the nose.
My balance point is 2.5 inches back from the leading edge of the top wing. Control throws are: elevator, up and down .5 inches, 30% expo; alerons up and down 7/16 inches, 25% expo; rudder, one inch, 30% expo.
Take off is fairly streight. Has plenty of power and will fly around fine at about 30 to 40% power. I will do all the normal aerobatics, loops, rolls, snap rolls, spins, etc. The wheels are big enough that one can operate off very short grass. Photos attached. I added a little camo and the roundels.
ID:	38382   Click image for larger version
ID:	38383   Click image for larger version
ID:	38384   Click image for larger version
ID:	38385   Click image for larger version
RBean is offline
Old 08-17-2007, 06:59 PM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
They need to sell this things with a non glossy covering...
FlyingMonkey is offline
Old 08-18-2007, 03:55 PM
WWI Ace
triplane test pilot
WWI Ace's Avatar
Hey RBean that's a very nice plane!!! It looks better than I thought from the pictures on the sellers website!! Steve.
WWI Ace is offline
Old 08-30-2007, 04:22 PM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
I love the Nieuport. I am going to have to scratch build this baby when I finish my SE5a. I agree with FlyingMonkey (hey! I AM a Monkey Minion!), don't make it in a glossy paint finish. Still, beautiful little plane.
Bob
Voyager2lcats is offline
Old 04-26-2008, 05:17 PM
steve crewdog
Default CG?
Hi Gang,
I've also purchased one of these, but the instructions show the cg at 3.5" back from the LE of the upper wing. With such a big difference I'm concerned. Any thoughts? (How did you come up with 2.5"?)
Thanks,
steve crewdog is offline
Old 04-26-2008, 05:43 PM
degreen60
Flying Fish
degreen60's Avatar
Now those red DR1s better watch out. HAHA
On my Camel that needed lot of the weight forward I just used 6 1800 Nimh cells mounted on the front of the firewall in an upside down U over the brushless motor. Did not have to add any extra weight.
Wonder if a coating of dull clear would get rid of the glossy look.
Sence I scratch build some of my planes I have to fly (read crash a few times) to find good location for COG. Just start over TALL grass and be ready to cut power.
degreen60 is offline
Old 04-27-2008, 12:10 AM
RBean
Hi Crew Dog. I e-mailed bu
RBean is offline
Old 04-27-2008, 12:14 AM
RBean
I'll try again crewdog. There was no cg info when I got mine. The first time I flew it, it was tail heavy and very twitchy. Had to add a little weight to the nose. CG is 2.5 inches back from the leading edge of the top wing. I rechecked it on the cg meter. It flys good this way. It may be I like more stability than others. Landings or ok also.
RBean is offline
Old 04-27-2008, 12:15 AM
steve crewdog
I like stable. If I want twitchy I'll go hang around with my crazy sister.
Old 04-27-2008, 07:50 PM
WWI Ace
triplane test pilot
WWI Ace's Avatar
There is a review of this plane in the new AMA Park Pilot magazine!!! Steve
WWI Ace is offline
Old 05-05-2008, 04:49 PM
7car7
7car7's Avatar
Default CG
I've got a book for RC modeling that discusses CG. (I bet many of you have it)
It shows that a straight wing, with a stagger like the Nieport is pretty easy to figure out.
Looking straight down on the plane, take the measurement from LE Top Wing, to TE Lower Wing. Measure 25% back from that combined number, there's your CG.
Example.
If each wing has a 5 inch chord, and the lower wing is 2 inches more to the rear, your measurement is a total of 7 inches.
Take 25% of 7 (1 3/4 inch) and that's how far back your CG is from the LE of the Top Wing.
What I find interesting is that doing this method, my Great Planes SE5a is a bit off from what the manual says. (Hmmmm...) But it is a great start for a plane that has no instructions, or a scratch build.
7car7 is offline
Old 05-08-2008, 03:44 PM
dai phan
Default Online review?
Can you please post a link to the review of this N-28? Thanks DP
dai phan is offline
Old 11-20-2008, 06:55 AM
Kmot
Kmot's Avatar
Howdy! I just noticed this thread at the bottom of a post I made in another thread about this model.
Yours looks great! I also love the rigging you made for it! I am going through that process right now. Can I ask how you mounted the rigging to the lower fuselage? It looks like you made brackets?
How has your model been holding up?
Kmot is offline
Old 11-20-2008, 09:57 AM
rhino
rhino's Avatar
If you "dust" it with a thin layer of a flat clear, it'll dull the finish down nicely.
rhino is offline
Old 11-20-2008, 02:35 PM
RBean
I made small bracketts with aluminum sheet, small screw and used ca in the screw hole. Used elastic thread for rigging. I still have the plane and it is holding up pretty well. Just learned it will do a great flat spin if you input opposite alerons during a spin. Recovery requires opposite rudder and down elevators.
RBean is offline
Old 06-02-2009, 03:31 AM
smit73
Default Help on the Nieuport 28
I just received my Nieuport 28. I bought the receiver ready version.
I was shocked by the lack of instructions. If anyone would not mind
helping me, I have some questions, as follows:
1. How do you attach the aileron servo box to the wing?
2. What did you use to attach the control rods to the servos?
Thanks for the help Bob
smit73 is offline
Old 06-02-2009, 05:00 AM
Kmot
Kmot's Avatar
Maybe this will help?
http://www.wattflyer.com/forums/showthread.php?t=40979
http://maxfordusa.com/manual/nieuport-m.pdf
Kmot is offline
details
WWI Era
27
02-13-2010 11:56 PM
spikkkkkkkk
WWI Era
77
09-30-2008 02:00 PM
delsol
WWI Era
12
07-10-2008 05:22 PM
CarreraGTSCS
WWI Era
10-16-2007 08:07 AM
Gnascher
09-25-2007 12:06 PM
Quick Reply: Nieuport 28 ARF
Page generated in 0.13310 seconds with 19 queries
