Wire pulled out of balance plug - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-07-2009, 11:34 PM
mpotter187
mpotter187's Avatar
Default Wire pulled out of balance plug
I had a wire pull out of the balance plug today it is a JST-X balance plug. It looks the wire just pulled loose, and I can pull the pin out and recrimp it or if needed solder it back on the put it back in the plug. Problem is I can't seem to get the pin out . I have tried to use a small flat blade to push the pin out from the top pushing on the tab but have had no luck and am worried about damaging the connector. Is there a trick to getting the pin out?
mpotter187 is offline
Old 01-07-2009, 11:39 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
the way you are trying should work. you might need to move the pin into the plug as far as you can before trying to depress the tab. If the wire pulled off, it likely pulled the pin back enough to jam the tab into the plastic.
xuzme720 is offline
Old 01-08-2009, 12:36 PM
mpotter187
mpotter187's Avatar
Thanks I will try again today and try to pop that pin out of there.
Old 01-08-2009, 01:31 PM
cliffh
This won't help your current problem, but anytime you toss out an old/damaged battery, cut the balance connector (and of course the Dean's connector!) for future use. Of course, make sure the battery is dead or tape wrap the wire ends. Those balance connectors can be a pain to repair, so it is sometimes easier to just replace the whole thing.
Cliff
cliffh is offline
Old 01-09-2009, 12:48 AM
mpotter187
mpotter187's Avatar
Took a bit more coaxing but I got the pin out and was able to repair everything. Thanks for all your help, I needed to get that pack back up and running so I could use my watt meter on my newly built eva sport before I maiden it once this stupid wind dies down.
rab23us
Beginners - Helis
09-15-2007 08:50 PM
robertloop
09-10-2007 02:59 AM
mtuhoop24
32
08-26-2007 04:23 AM
CitaFly
22
08-14-2007 04:07 PM
1987tc
08-03-2007 06:04 AM
Quick Reply: Wire pulled out of balance plug
Page generated in 0.05785 seconds with 13 queries
