GWS company question - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Company Discussions Discuss your company experiences here.
Old 01-08-2013, 12:29 AM
hangingon
hangingon's Avatar
Default GWS company question
I was reading fourms and watching videos on the gws slow stick I bought so I was trying to find out all I could. I came across some I guess old GWS news that they were going under and then when I looked at adds for their products that was in my package it was dated 2010. I looked at online stores and alot of GWS stuff show's as backorder. An add on their website for new servos was 2010 news. Did I just buy another plane I'm going to have problems getting parts for? If so the airframes are pretty cheap so I thought of buying 2 more so I will have extra parts.
hangingon is offline
Old 01-08-2013, 01:50 PM
crxmanpat's Avatar
The Slow Stick is probably the only thing that has kept GWS afloat the past several years. You should have no problem getting parts for it. In fact, just get an NPS (No Power System) kit and you have a box full of spare parts right there.
If not, ALLeRC (www.allerc.com) or Gorilla Bob's (www.gorillabobs.com) are good sources for parts.
crxmanpat is offline
Old 01-08-2013, 02:45 PM
subzJC
flyer
It seems to me that the hardest part to find is the brushless motor mount.
It looks like gorillabob still has some of the plastic ones but most every other
place i have looked does not have them. I bought the aluminum one at HURC
and it is very strong. I had a ground stike on a takeoff and it actually splintered
the boom and ripped the mount right off but no damage to the mount.
I see that HURC is out of the aluminum ones now as well but did find them
here http://smallpartscnc.com/index.php?r...product_id=111.
Hopefully that will link up. These slow stick are a lot of fun and can be flown about anywhere. I hope you enjoy yours. Dont forget to add the ailerons. If your going to glue your servo to the wing I found that you need to cut the skin off to get good
adhesion.
subzJC is offline
Old 01-08-2013, 08:22 PM
crxmanpat's Avatar
The great thing about the Slow Stick is you don't HAVE to use genuine replacement parts, such as the motor mount, D Frame plastic parts (like the wing mounts and such), and wheels. You can find lots of places selling aftermarket parts for it.
Like subzJC said above, the metal motor mount is great, and better than the plastic stock one if you ask me.
Old 01-09-2013, 01:33 AM
hangingon
hangingon's Avatar
Thanks guy's I seen the aluminum motor mount last night on a site just can't remember which one. I got my SS from heads up rc and in a message that they sent as a reply to a ? I had they could only get the blue SS kit w/bl motor. They couldn't get the blue ARF. I bought the blue SS because it came with the brushless. Now for replacement parts I can't find the blue I plan to order at least 2 ARF kits I found 1 blue kit no electronics and they charge 2 or 3 dollars more than the red or yellow I don't care what color it is.
Old 01-09-2013, 01:53 AM
hayofstacks
hayofstacks's Avatar
Blue slow sticks are the way to go .
I had the aluminium motor mount and a e apc prop. When my prop would strike on hard landings, it would split and shatter the fiberglass fuse. I have sine upgradded to a thick walled 10mm cf fuse, and its so much stronger it isn't even funny. I actually broke the aluminium mount, I lost signal with my dx6I and recovered just before hitting the ground. I gave it full throttle and full up(240 watts btw), cleared the ground, but not the top of the fence at the other end of the feild.
I plan to upgrade to a 480 class motor, about 450w, to help with the verticle performance from all the weight I have added with my bipe kit.
Beef up your landing gearb put some larger 3" gws parkflier wheels on it if you can find them, and have some fun.
hayofstacks is offline
Old 01-09-2013, 02:51 AM
For all your slow stick needs... only better...
http://www.millenniumrc.com/
Old 01-09-2013, 03:11 AM
mattman0182
Luftwaffe Ace
mattman0182's Avatar
There is a BF109 in the lhs in my area made by this company. But I'd never find parts for it.
mattman0182 is offline
Old 01-09-2013, 11:06 AM
subzJC
flyer
Good call firemanbill,
and all made in the USA, I really like that.
bookmarked for sure. Thanks!
subzJC is offline
DCDetector
10-27-2012 08:17 AM
lawdog89429
Foamies
11
08-25-2012 05:47 PM
intimidator_md
11-29-2011 01:04 AM
Hose Man
03-23-2011 01:57 PM
Quick Reply: GWS company question
Page generated in 0.06438 seconds with 12 queries
