Looking for a flight/helmet video camera
Ochroma Pyramidale Tekton
Ok, I checked this forum, I did a search, and so far all I've come up with that will even work is the flycamone. but what I really want (and I saw something along these lines, but forgot where) is something ideally:
Resolution is not super important, good enough for around 600x400 Px. is fine with me. Oh, and not too expensive, please ($50 - $100 range ideal).
- Small, "pen-light" style lens/pickup preferred.
- Seperate (wired or wireless) recording unit.
- Would be lightweight and easy to mount on either a sailplane OR a bicycle Helmet. Record unit could be stored inside plane (or jersey pocket). Or if wireless, on the ground, safely with me.
- Should be capable of around 10 minutes of video recording (more is obviously acceptable).
Hello Flywheel,
Here's a couple sources;
http://www.intelligentflight.com/sto...index&cPath=11
http://www.boostervision.com/cart/sc...?idCategory=36
And, if that's not suitable, check the "Builders Links" under Aerial Photography, Flight Data or FPV. http://www.wattflyer.com/forums/showthread.php?t=14117
Hope this helps!
Ron
Hope this helps!
Ron
