Gear Replacement On HXT900 Servos
Old 08-13-2009, 04:41 AM
Marc
Marc's Avatar
Build Review Gear Replacement On HXT900 Servos
Get out your box of crash damaged HXT900 servos that have jammed, stripped, or broken gears and fix them. HobbyCity sells replacement gear sets for $0.99, and it only takes 5 minutes to replace them. Here's how to do it:
Step 1: Remove the servo arm. Use a small Phillips screwdriver to remove the 4 screws that attach the cap to the servo body and remove the cap.
Step 2: Remove the idler spindle and associated gears. Lay the gears out in the order removed so that the replacement gears can be exactly matched to those removed.
Step 3: Grasp the upper drive gear that the servo arm attaches to and pull it straight off. This will take a good tug. Remove the lower gear as well.
Step 4: Lubricate the replacement gears with a light coating of petroleum jelly. Some may prefer KY. Now replace the spindle and stack the gears in the appropriate order.
Step 5: The drive gear to which the servo arm attaches must be pressed on. Align the cogs as best you can. Invert the servo and press the gear straight on against the workbench.
Step 6: Replace the cap on the servo body. Replace the 4 screws that hold them together. Replace the servo arm. Test the rebuilt servo to be sure that it works smoothly and you're done.
ID:	107236 Click image for larger version
ID:	107237 Click image for larger version
ID:	107238 Click image for larger version
ID:	107239 Click image for larger version
ID:	107240 Click image for larger version
Marc is offline
Old 08-13-2009, 12:05 PM
Be sure to clean things up real good too. You dont want any broken off teeth flaoting around in there!
Page generated in 0.09830 seconds with 14 queries
