pole count
Old 07-31-2012, 10:11 PM
RobT
Default pole count
All things being equal, what does increasing the pole count do to an electric motor? (ie some are 14 poles, others 28 poles).
Thank you,
Rob
RobT is offline
Old 07-31-2012, 10:25 PM
Reduces the kv rating, makes the motor spin slower but with more torque.
Old 08-01-2012, 12:49 AM
RobT
But if two motors had the same kv, but a different number of poles, what would be the effect?
RobT is offline
Old 08-01-2012, 07:11 AM
If the specs are similar, i.e. similar weight and size, similar kv, then I'd expect them to perform in a very similar way regardless of pole count.
Old 08-01-2012, 01:25 PM
RobT
Thank you.
RobT is offline
Old 09-01-2012, 05:07 PM
Dr Kiwi
To get the same Kv, the motor with the fewer poles would need more turns (and thus maybe thinner gauge wire)... or the motor with the greater number of poles would need fewer turns (and would use heavier gauge wire)....that might well affect performance.
Dr Kiwi is offline
RobT
17
07-30-2012 07:09 AM
jcerne
12-25-2011 10:09 PM
crobar
01-24-2011 08:31 AM
Quick Reply: pole count
Page generated in 0.06859 seconds with 13 queries
