Help with Extreme Flight Yak 54e
Old 12-29-2008, 10:47 PM
HomeDaddy
post hole digger
HomeDaddy's Avatar
Default Help with Extreme Flight Yak 54e
Just a few questions.
I know the manufacturer calls for a Torque 820 but i will probably be using a Torque 900. From what i know, this should be ok. I may also use a Turnigy setup if my deal on the 900 falls through. Anyone tried this? What motor?
Any tips on keeping it light?
What c rating batteries would be best? Also, what mah would I need to get 10 mins of sport flying out of it? I'll be using a thunderbird 54.
Thanks and sorry for so many questions! I'm a noob to this type of plane.
HomeDaddy is offline
Old 01-07-2009, 10:26 PM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Hey bro. Did you decide what you were wanting to do? Did you go with the 900 or turnigy?
Mike Parsons is offline
Old 01-07-2009, 10:36 PM
pburt1975
Hotel California
pburt1975's Avatar
I dont know if this helps much but Simibill had one up for sale not long ago.
http://www.wattflyer.com/forums/show...Flight+Yak+54e
C rating of the battery will depend on the power system requirements and the MAH of the lipo you are trying to use.
If the system needs 20 amps, you need either a 2200mah lipo at 10c (meaning it will provide 22amps constant) (good to have a little give) or a 1100mah lipo at 20c.
cant help on time estimate. You can try flying for 5 min then check the individual cell voltage if it is still in range then recharge the pack and fly for 7min and check voltage.. sorry, I dont know an easier way??
another thread on here, found using the search feature, that may help give you some advice
pburt1975 is offline
Old 01-07-2009, 11:38 PM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Flew mine with the recommended 820 on 3s and 4s. The 13 x 6.5 prop seemed to work well given the bucket of a cowl. 14 x 7 was a nice size on 3s but a little lacking in vertical. 4s seemed perfect=I used the 13 x 6.5 and watched my throttle-didn't really need WOT. Not the recommended prop size on 4s but it worked and didn't get the motor hot. A 12 x 6 is kind of a small prop for the larger nosed Yaks as recommeded for the 900. Not much prop hanging over the diameter of the cowl. It should fly but I'd be a little leary of it unless you keep your speed up. My .02.
EDFrules is offline
simibill
07-04-2008 11:01 PM
keznancehdy
06-25-2008 04:22 AM
luv2fly2
11
09-30-2007 10:21 PM
luv2fly2
09-18-2007 08:19 AM
MLT67
09-06-2007 03:46 AM
Quick Reply: Help with Extreme Flight Yak 54e
Page generated in 0.06410 seconds with 10 queries
