Gloves or no gloves ?
Old 01-10-2012, 12:25 PM
FlyingBrick50
FlyingBrick50
FlyingBrick50's Avatar
Thumbs up Gloves
I have used gloves like these before they work well
http://casanovasadventures.com/catal...hing/p6018.htm
FlyingBrick50 is offline
Old 01-10-2012, 02:08 PM
Originally Posted by TM4197 View Post
These gloves are very cheap, usually in a pack of 12-15 pair for about 7 bucks. You can find these in Asian stores, some gas stations also sell these. Cotton light latex coated fingers and palms. Put a couple in your pocket to warm up. As soon as your hands feel chiled, change them out. The latex makes a perfect grip, you can even pick up small screws. The feel to the Tx is great.
your link doesn't work for me ... but they sound same as what I am using ... thin cotton with
Old 01-11-2012, 05:37 AM
spog
This is what I use which allows me to fly comfortably at -20C.
-90 watt heater with fan to distribute the heat
-dual 12volt power source, external(car) or 3S lipo with low voltage cutoff, auto switched to external when plugged in.
- cut off gloves to seal hands
-spring loaded foam doors to retain heat between flights
-external throttle cut switch
-thermostat temperature control, set to 90F (max)
-radio display lighting
-runs 30-45 minutes on a 2200mah LIPO if preheated in the car
I love having sweaty hands at -20C, best thing I ever built for RC
Name:	IMG_0209 (1024x768).jpg
ID:	156292   Click image for larger version
Name:	IMG_0210 (1024x768).jpg
ID:	156293   Click image for larger version
Name:	IMG_0211 (1024x768).jpg
ID:	156294   Click image for larger version
Name:	IMG_0212 (1024x768).jpg
ID:	156295   Click image for larger version
Name:	IMG_0213 (1024x768).jpg
Name:	IMG_0214 (1024x768).jpg
ID:	156297   Click image for larger version
ID:	156298   Click image for larger version
ID:	156299   Click image for larger version
spog is offline
Old 01-11-2012, 06:55 AM
Must admit that I'm considering one of those 12w Hot / Cold boxes ... you can get the little ones for a 6 pack of beer size .. only thing ... what temp is the HOT phase ? If it's anything like the cold function - probably not too high.
lvjet
New Product Announcements
10
04-26-2013 06:42 PM
Quick Reply: Gloves or no gloves ?
Page generated in 0.09990 seconds with 25 queries
