Paint or cover?
Old 01-08-2009, 09:43 PM
gazzacov
Warm thumbs = More funs!
gazzacov's Avatar
Question Paint or cover?
Hi guys. (& Gals!) I've accumilated a few spares along my way, mainly for my park flite cessna (son still learning). Instead of buying yet more decals, i thought about painting a spare wing/fuse etc and transferring the internals over, so he has an individual plane. What i'm struggling with is finding a spray paint that will paint foam (i call it expanded polystyrene) without melting it. I know through research you have some stuff in the US, but to get it here in the UK would be too expensive. Then i thought about solarfilm, untill i remembered you need to heat it on... not good. Does anyone have any thoughts/experience? Have searched through here everywhere but cannot find any threads previously posted related to covering or painting.
gazzacov is offline
Old 01-08-2009, 10:30 PM
constantCrash
prefectionist
constantCrash's Avatar
Krylon H20 will work but colors are limited and heavy, I've heard Krylon short cuts will also work. (try on a beer cooler first ). if you have or can get an airbrush that's the best way to go (I don't have one yet), with that you can use any Acrylic paint with some rubbing alcohol or water to thin it out.
As for covering anything with low temp will work. TowerKote/EconoKote I believe solarfilm is or makes a low temp covering. The foam will bead a little bit but it won't melt.
constantCrash is offline
Old 01-08-2009, 10:58 PM
max2112
max2112's Avatar
Default I covered.
I have used Econocote to cover a foam airframe before assembly recently. It turned out pretty decent. I will be able to post up some pics in a little bit but it is doable.
I used an old style hobby iron and left it on a low setting.
Good Luck & plz keep us posted!
max2112 is offline
Old 01-09-2009, 12:26 AM
max2112
max2112's Avatar
Default Econocote covering on foam.
Here we are.
These pics are of a Phase 3 F-16 that I got for Christmas. I did the wings , tail and fuselage sepaerately before assembling with 5 minute epoxy.
The pictures are actually pretty forgiving. I made several mistakes that ended up being major wrinkles.
I never put the Iron on more then 2 & 1/4. I was afraid of melting or warping the foam.
I think it worked pretty good.
ID:	89692   Click image for larger version
ID:	89693   Click image for larger version
max2112 is offline
Old 01-09-2009, 01:41 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Coverings For Foam?
Hallo Gazzacov, Welcome to Wattflyer!
CC and John have given you some good advice already, I will only add that the question of which coverings are suitable for different structures has come up before and I put together this reply;
http://www.wattflyer.com/forums/showthread.php?t=18843
Also, on the sticky at the top of this Forum, "New Builders Links", scroll to the "Coverings" category. There are several links for various covering methods as well as a weight chart for many covering types.
Hope this helps, Good Luck!
Ron
Sky Sharkster is offline
Old 01-09-2009, 04:37 AM
Hi Gazzacov I like using krylon Short cuts paints on foam, test first, and use in thin coats, I also like using Monokote trim tape for trim, it works great and is lite weight, the krylon H20 paint is kind of heavy, as its a latex house type paint, but it works, best to use with larger planes, the monokote comes in a section 5x36 and is self sticking, it comes in different colors too, here is a pic of my corsair, painted with the Short Cuts spray paint, take care, Chellie
http://www.misterart.com/store/view/...Short-Cuts.htm
http://www.hobbypeople.net/gallery/535302.asp
Top Flite Monokote Trim Missile Red 5 x 36
ID:	89732   Click image for larger version
Old 01-09-2009, 10:45 PM
gazzacov
gazzacov's Avatar
Nice colour on the Corsair Chellie! Thanks to all for the info, I'm looking through it all in between drinking tea and eating chocolate. Krylon shortcuts seem to be the answer to my prayers, but hard if not impossible to get here in the uk, and being airosol means no airmail. Good tip about solarfilm there, been years since i used it, but might give it a try on some scrap foam, if i can relocate my old iron. will keep an update on the links mentioned for coverings etc, in case its any help to others. Thanks again everyone.
Just read through the section on coverings posted by Mr. Sharkster... Nice work! Very informative, have saved a copy on my pc for future reference.
gazzacov is offline
sheldo78
11
01-11-2009 12:57 AM
michael7810
Foamies
09-23-2008 05:20 AM
paranoia
Ebay for sale
05-07-2007 09:25 PM
onrecess
Delta & Flying Wings
01-22-2006 01:20 AM
Quick Reply: Paint or cover?
Page generated in 0.10108 seconds with 19 queries
