Any one fly ikarus yak 54
Old 08-10-2005, 09:45 AM
DannyFlyer
Default Any one fly ikarus yak 54
is the ikarus yak 54 better or worse then the e-flight yak 54 pros and cons for both if you can tell me that
DannyFlyer is offline
Old 08-10-2005, 06:51 PM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Hi Danny,
Having owned/Own Both they are completely different. The E-flite is heavier than the Shocky Yak by an average of 5-6 oz and therefor takes a step up in motor and battery requirements. Both fly great and are loads of fun. The Ikarus is a good no wind flyer as at 7oz, it can get knocked around pretty quickly. The Eflite at 12-14 oz, handles wind better, but again fly's a bit heavier.
Here is my equipment:
Ikarus Shocky Yak:
Torque 34T Outrunner
Pheonix 10 ESC
2S 730 Thunderpower
8X3.8 APC E
Eflite Yak-54
Torque 26T
Eflite 20a ESC
3S 830 and 900 pack
9x3.8 APC
Mike Parsons is offline
Old 08-10-2005, 09:45 PM
DannyFlyer
how do you think that motor on the e-flight yak will do at colorado attitude 6000ft.
Old 08-10-2005, 09:59 PM
Slowroll90
hey
i know that glow and gasoline engines are effected by the low density air of altitude by how could an electric motor be affected by this besides mabey the prop not making as much thrust
i have a ikarus yak 54
eflight 370 outrunner 1080
Castle creations phoenix 10
thunder power 3 cell 900mAh
this setup is extremely powerful but is slightly overweight but flies fine.
Slowroll90 is offline
Old 08-10-2005, 10:03 PM
Mike Parsons
Danny,
You will simply need to swing a bigger prop. I would say a 11x3.8 (plenty of clearance for up to a 13" prop).
Old 08-10-2005, 11:47 PM
DannyFlyer
I estemated about 12.7 oz rtf weight I would like an inexpensive motor and esc the coule produce about 24oz of thrust Himax 2808-0950 is a combo for norh est sailplane products is 90.00 and has 24oz of thrust power
Old 08-15-2005, 11:08 PM
Ron
I use the Eflite 370 outrunner 1080kv...cc 10 controller....2S 750 lithiums...10X4.7 prop APC slowfly.......7.5 ounces....lots of power, and not a bad flier.....
Ikarus Yak
Ron is offline
Old 08-22-2005, 12:35 PM
PiedmontQC
PiedmontQC's Avatar
I have the Shock Flyer Yak-54, my setup is...
Esskay 400XT motor
E-Flight 20 amp speed control
Fma M5 Rx
Hitec HS-55 servos
Kokam 900mah 3 cell and 640mah 3 cell
I never installed the wheel pants and I put 2 inch microlite wheels on it.
I fly outdoors and takeoffs from grass take about 3 feet. So far the wind has never stopped me from flying.
.................................................. ...........................Al T.
PiedmontQC is offline
Old 02-03-2009, 11:19 PM
samchamp
footewesterner
Hi,
I just received the Ikarus Yak 54 Shock flyer and I think the instructions leave a lot to be desired. On the T/E of the wing, there is an angular notch but I cannot see anything in the instructions showing the detail. I'm sure the CF rod goes there but how??
Thanks,
Larry D
samchamp is offline
ARTP47
ParkFlyers
07-24-2007 05:26 AM
Blue Max
Foamies
02-18-2007 06:26 PM
ryanotown22
Seaplanes E-Powered
01-26-2007 10:54 PM
EDFrules
3D Flying
11-21-2006 01:04 AM
Harleyflyer
Foamies
09-07-2005 04:19 AM
Quick Reply: Any one fly ikarus yak 54
Page generated in 0.12254 seconds with 13 queries
