Plans?
Old 01-28-2008, 02:46 PM
Papaw14
Default Plans?
Would anyone have any plans for an airplane that can use a SLO-V flight pack? Someone flew my SLO-V through a fence, stripping it of wing and tail. It might have been me.
Papaw14 is offline
Old 01-28-2008, 03:37 PM
offtom
Megans Servant
offtom's Avatar
Might be easier if you just bought a new wing and tail feathers for what is left, that is if there is anything left. Those fences can be pretty unforgiving sometimes.
offtom is offline
Old 01-29-2008, 02:13 PM
jb48
I think that if you don`t want to get another Slo-V (and I`ll understand you), you will have to stick to another V tail plane about the same weight than the Slo-V. The tx/rx/esc original Slo-V combo is programmed for V tail operation.
jb48 is offline
Old 10-21-2010, 05:36 AM
rcsuperhero
rcsuperhero
removed comment - rcsuperhero.com
rcsuperhero is offline
Old 10-21-2010, 12:40 PM
philipa_240sx
This can be changed by swapping the jumpers on the RX brick. The RX is shared with the PZ Super Decathlon and J-3 Cub. I got this from the PZ Super Decathlon User Manual:
Orientation:
(See photo of jumpers below)
J1 J3
J2
Options:
J1: In = Rudder to Elevator Mix (Supposedly to reduce altitude loss when turning), Out = No mix
J2: In = V-tail, Out = Conventional tail
J3: In = LVC set for 6-8 cell Ni-mh, Out = LVC set for 9 cell Ni-mh or 3S lipo
philipa_240sx is offline
Old 10-21-2010, 12:52 PM
philipa_240sx
As for plane suggestions...
The most obvious and easiest to assemble is the GWS Slow Stick kit:
http://www.headsuprc.com/servlet/the...K--dsh-/Detail
You have to get creative with the motor mount. Probably the easiest will be to use a 2" L x 3/8" square wood stock.
1) Shave it down so that it fits both the SS 10mm aluminum fuse and the 8mm Slo-V motor mount.
2) Use a screw and epoxy to secure it in the SS fuse.
3) The motor/gearbox should be secured to the wood stick with a screw... but not from the front like stock. Drill a new hole from the bottom of the motor mount... perpendicular to the wood stick.
Another option:
If you don't mind scratch building, then have a look at the 42" Blu-Baby plans on RCG.
Phrozius
02-08-2011 10:02 PM
toffas
02-08-2011 09:32 PM
dotyj
General RC E-Heli Talk
12
07-13-2007 03:59 PM
3D-Flyer Kevin
Combat
05-28-2007 02:46 AM
sanka
ParkFlyers
04-21-2006 09:47 AM
Quick Reply: Plans?
Page generated in 0.13931 seconds with 13 queries
