Parkzone Vapor BNF problem
Old 07-03-2008, 11:29 PM
yohan753
Default Parkzone Vapor BNF problem
Hi guys. I just received my Vapor BNF today.
I am using the TX from my Blade CX2 (LP5DSM)...I've followed the binding instructions, but it appears something is wrong as when I turn left on the TX the plane turnr right and vice versa....so it seems to be backwards.
Has anyone else experienced this?
Thanks!
yohan753 is offline
Old 07-04-2008, 04:20 AM
ontheedge
I'm not familiar with the Blade radio. Does it have servo reversing?
ontheedge is offline
Old 07-04-2008, 04:39 AM
gfdengine204
gfdengine204's Avatar
Thanks!
Are you talking about AILERON control or RUDDER control?
The LP5DSM has DIP switches for servo reversing; they are located unde the door on the bottom left of the transmitter.
DO NOT CHANGE THE POSITION OF SWITCHES 1-4; THE TRANSMITTER MAY STOP FUNCTIONING NORMALLY. (This is from E-Flite; I have no clue as to the truth of this statement.)
If you wish to reverse the AILERON servo (should there be one), change the DIP switch marked 6; to reverse the RUDDER change DIP Switch number 8. (For reference DIP 5 is THROTTLE, DIP 7 is ELEVATOR)
gfdengine204 is offline
Old 07-04-2008, 06:29 AM
yohan753
Awesome....thanks for the tip. I'll give that a try and post the results tomorrow.
thanks!!
yohan753 is offline
Old 07-04-2008, 06:58 AM
Rabbitcreekok
Rabbitcreekok's Avatar
If you make the switch, be sure to change it back before flying the CX2.
Rabbitcreekok is offline
Old 07-04-2008, 05:00 PM
gfdengine204
Good point Jim. Nice catch.
Old 07-04-2008, 05:37 PM
yohan753
Thanks for the tips everyone! It worked like a charm.
I've flown inside the house with no problem and outside in my backyard with a slight breeze...this thing is a blast!
yohan753 is offline
Old 07-17-2008, 11:17 PM
Ram008
For flying the CX2, dip switches 1, 6 and 7 should be in the up position, all others in the down. For flying the Vapor, all of the dip switches should be in the down position.
Ram008 is offline
Old 07-23-2008, 10:00 AM
Numb Thumbs
Numb Thumbs's Avatar
There is a great little table here:
http://www.rcgroups.com/forums/showthread.php?t=611167
which details what all the dip switches do. It is setup for Mode 2 so I had to fiddle a little... My Vapour mixed Elevator and Aileron about 100% so I had to fix that! Now all is fine.
For me, on Mode 1 here in Australia, I have set:1 - on; 2, 3, 4, 5 - off; 7, 8, 9, 10 - off.
Numb Thumbs
Numb Thumbs is offline
Tommyr
364
08-21-2011 01:47 AM
rdr4evr69
10-04-2008 03:08 PM
hunter306
09-16-2008 10:21 PM
pritpal
08-22-2008 02:16 PM
Quick Reply: Parkzone Vapor BNF problem
Page generated in 0.08598 seconds with 14 queries
