ideas for 3d foamie
Old 12-12-2008, 05:13 AM
kyle pepp
flash burn thanks for the great info i lloked it all up and got me a parts list and its about 100 lesss the my parts list for the extra 260
thanks alot
kyle pepp is offline
Old 12-12-2008, 04:18 PM
flashburn
Glad to help Kyle; Post a picture of your setup once it's done.
flashburn is offline
Old 12-12-2008, 11:44 PM
kyle pepp
i wish i could make it soon but i need a job first to get the money...i just wanted to get a good idea first so yea
right now i have a blade cx2 and just recently i got a gws pico stick so it will be a while before i et one of these
Old 12-28-2008, 06:53 PM
kyle pepp
well in case any of u till care or are interseted i orders a junior yak last night form dw foamies
Old 12-28-2008, 08:23 PM
Figure.N9ne
Figure.N9ne's Avatar
you made a great choice, kyle! i must have over 100 flights on my dw foamie in the past 3 weeks.
Figure.N9ne is offline
Old 12-28-2008, 08:27 PM
kyle pepp
nice...what power system are u using with yours and what size prop
Old 12-29-2008, 07:09 AM
Figure.N9ne
i'm not flying a 28 inch model, i'm flying the 48" juka on a scorpion 3014-18 and a 12x3.8. give mike morgan at DW a call, he'll be happy to recommend a power system and prop for it.
Old 12-29-2008, 06:07 PM
darylm44
darylm44's Avatar
I have always stayed with the recommended prop for most of my airplanes, but have just learned what the right prop can do. I have been flying my Hobby Lobby Yak 55 with the TURNIGY 2204-14T 19g Outrunner. I have tried several APC electric props 7-6 to 9-3.8 and always thought the plane lacked power. Yesterday I tried a GWS EP 8040 and it flew like a totally different plane. I had been using a APC 8-3.8 which I thought should be similar but what a difference.
The GWS is thinner and lighter so I guess that makes the difference.
darylm44 is offline
Old 12-29-2008, 08:00 PM
kyle pepp
im getting the power system on the website from him i was just wondering if u changed urs at all
i plan on using a gws 8040 prop on mine
mike said it chould come in 2 days
Old 12-29-2008, 08:21 PM
groundrushesup
groundrushesup's Avatar
The 9mm fuselage is perfect for a beginer, and its not that much more heavier, and thats where you need the strength at, on your foamy combat plane, i would use fiberglass straping tape, from wing tip to wing tip on the top and bottom, about 1 1/2" to 2 " wide is good, and use some clear packiung tape on the leading edge, of the main wing, that will make it very strong and not add that much weight, and will help it to live, when learning, a little down thrust will help the plane to be stable, about 3 degrees, and you dont need any right or left thrust, just a little down thrust, hope that helps, Chellie
http://www.wattflyer.com/forums/showthread.php?t=30651
hahah good ideas, Chellie - unfortunately I got excited to fly mine and I put it up without packing tape on the LE's or the CF Tow I have since added to the underside of the fuse.
Anyways, long story short I forgot to check the aileron direction before I tossed it and ened up having to fly it backwards for a few minutes until I could try to deadstick it in without destroying it - I managed to get it home with just a bit of a gouge in one of the LE's from a branch lol but man, it flew GREAT!
All I had in the box was the APC 9x3.8SF but it flies great with the x-thin Zippy 1000mAh batteries. It was really nose heavy at first, too. Thanks so much for the recommendation!
GRU
groundrushesup is offline
gzsfrk
3D Flying
128
10-21-2009 02:40 AM
fflier9
11-09-2008 06:45 PM
rednote
Foamies
8
11-05-2007 04:08 PM
Ben-Rod
Foamies
23
02-27-2007 05:52 AM
Topdoc
Foamies
11
03-27-2006 01:40 PM
Quick Reply: ideas for 3d foamie
Page generated in 0.11576 seconds with 13 queries
