Go Back  WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > ParkFlyers
Reload this Page >
Wing Dragon/Wing Dragon 4/Begin-Air Series Planes Tips & Tricks
Old 07-06-2009, 11:39 PM
Unintentional_Loop
Originally Posted by floridawen View Post
I just ordered a Wing Dragon 4 and read on several posts here that it is advisable to GLUE the WING HALVES together for rigidity and support. I was wondering WHAT IS THE BEST GLUE to use for doing this ?? Presently I have Loctite Professional 60 MINUTE EPOXY, is this the BEST ??
I considered gluing my WD4 Wings together but decided that I may need to dismantle them at some point in the future, so I fixed them together with Glass Reinforced Tape. It's very strong stuff and you can't tear it, but it can be cut if you find you need to disassemble your wings.
Being across the pond, so to speak, I can't recommend any places where to buy the tape, but I'm sure if you google "glass reinforced tape" you'll easily find a supplier
Unintentional_Loop is offline
Old 07-07-2009, 05:28 AM
Sir Raleigh
Glass reinforced tape = Scotch Extreme Tape.
Bill
Name:	Scotch Extreme Tape.JPG
Sir Raleigh is offline
Old 07-08-2009, 06:57 AM
galaxiex
galaxiex
I used 30 min. epoxy on mine, added a CF spar, and covered the wing with Sig Aerokote Lite.
Makes for a VERY stiff wing!
galaxiex is offline
Old 07-08-2009, 12:49 PM
floridawen
floridawen's Avatar
WOW ..... You really strengthened up your wing !!
floridawen is offline
Old 07-08-2009, 08:12 PM
galaxiex
galaxiex
Yep, I'll put some pics up later if you like...
galaxiex is offline
Old 07-08-2009, 08:15 PM
floridawen
floridawen's Avatar
That'll be GREAT ........... THANKS !!
Old 07-09-2009, 03:20 AM
galaxiex
galaxiex
Sorry took so long to get pics up, I was at work when I posted that...
Anyway, here ya go.
The Sig Aerokote Lite orange is a very close match for the WD4 original color.
I covered the wing halfs and then epoxied them together, also epoxied the black rubber band protector on.
Carbon pins fit into holes in the plastic body of the plane, wing mount area.
I was having issues with the wing shifting in flight.
Also made balsa ailerons and used pin type hinges and of course covered the ail's too.
Fitted HS-55's for the ail's.
Oh, my mistake, this wing does not have a carbon spar, I put that in a different plane and was thinking of that one when I said that.
ID:	104969   Click image for larger version
ID:	104970   Click image for larger version
ID:	104971   Click image for larger version
ID:	104972   Click image for larger version
galaxiex is offline
Old 10-08-2009, 08:30 PM
Sir Raleigh
Default Parts Supplier Update
Added a new parts supplier to post #1.
http://www.nitrotek.co.uk/products.php?cat=43 ( Appears to be a supplier for Great Britain, Spain, and Europe)
http://www.thegoodiesmartrc.co.uk/wi...arts-200-c.asp (UK Dealer)
Bill
Old 10-23-2009, 05:18 AM
colvid
Default Twin Engine and a Front Engine Wing Dragon 4
Mounted an engine on the front of a Dragon and moved the servos to just under the rear of the wing for proper CG. Flys great and the twin engines flys great just so long if you give it too much trottle and it goes crazy.
IMG]http://i63.photobucket.com/albums/h156/colvid/Wing-Dragon-Eng-on-Front.gif[/IMG]
colvid is offline
Old 10-28-2009, 01:42 AM
road_rascal
I posted this on RCGroups but I thought I'd post it here too: I borrowed a friend's GPS logger and put it on my Wing Dragon to see how fast I could get it. I managed 86mph in the first dive and 82mph on the second and third. This is using a TowerPro 2409-12T, Master Airscrew 7x4x3 prop and a Rhino 3S1750mAh lipo. Once the wind dies down I'll get a few straight line passes to see what speed I'm getting.
road_rascal is offline
Old 10-29-2009, 04:31 AM
colvid
Default 86 MPH is Fantastic!!!!!!
Those speeds are great, especially with that size motor. Have replaced motors with much larger but do not think that they are that fast, however when I give them full throttle, they go out of control all over the sky. I still consider myself to be a novice, which may be the problem!??
colvid is offline
Old 10-29-2009, 02:22 PM
road_rascal
I know that on the second Wing Dragon/ Begin Air plane I built it is slightly tail heavy. This is due to the fact that I have the ESC and receiver mounted under the wing (in the open pod area) instead of the nose like my other one. I think I may try cutting 1/2" off of the tail boom and see how it flies. I think I also saw a post somewhere stating the the pusher motor should not have any downthrust or angled left/right.
Old 10-29-2009, 05:34 PM
  #63
colvid
Default Wing Dragon
Have had the problem of being tail heavy but never thought about shortening the rear boom. Let me know the results if you do. Angle and down thrust of the motor is easy to try.
Have enclosed photo of the motor mounted on the front. Moved the servos just under where the pusher motor would be. The motor has since been replaced with a larger motor to compensate for the the extra weight of the servo platform and the larger landing gear. Rudder also controls nose wheel.
Have only flown twice and it flys okay.
colvid is offline
Old 11-18-2009, 04:52 AM
  #64
colvid
Default Wing Dragon Four w/motor on the front
Have only flown this one twice. It is nine ounces over the stock one I have. Have to take off fast and maintain a good speed, but it is still fun.
colvid is offline
Old 11-19-2009, 12:32 AM
  #65
colvid
An interesting looking WD but Wow! 9 ounces over stock.
I must say I prefer to go the other way and see how much below stock I can get. Currently at 16 ounces with a 1500mAh 3s and a performance to match.
Old 11-19-2009, 05:04 AM
  #66
colvid
Default Wing Dragon
Hi quorneng:
Flew the more normal WD today (brushless) with about 5mph wind. Keep forgetting how long an approach in order to land it. Have attached a photo of a twin motor Dragon. I learned from this one and another with a large motor that the plane can not handle it w/o going all over the sky.
Larry
colvid is offline
Old 11-20-2009, 12:46 AM
  #67
That's one advantage of going lighter. A reasonable thrust, say 18 ounces, gives near vertical performance but at a torque that the WD can easily handle.
It also helps to use a relatively fine pitch prop. It gives good climb thrust but it falls off quite quickly as the speed builds up so helping to keep things under control.
This is my lightweight, hand launch, 17 ounce version with differential ailerons, no rudder, the elevator servo in the fin and flaps.
A simpler wing without flaps and the weight falls below 16 ounces.
Old 11-20-2009, 01:13 AM
  #68
colvid
Default Lightweight WD
Really a clean look, but you lost me on the differential alierons etc.
colvid is offline
Old 11-20-2009, 01:37 AM
  #69
Differential ailerons - more "up" than "down". This means more drag on the up (inside) aileron than on the down (outside) so it helps the plane into a turn.
Equal up and down ailerons cause the plane yaw the wrong way as with the same movement the down aileron creates more drag than the up one so some rudder is required as well to make the plane turn correctly.
So with differential ailerons you only need a fixed fin and can do away with the rudder servo.
The flaps (using the rudder channel) were an experiment to see how slowly it could be made to fly and it is indeed pretty slow.
Old 03-19-2010, 03:16 AM
  #70
Ianh
Default Two for One
I have been reading this forum with keen interest as I am learning to fly with one of these planes. I too had the same problem with the control rods being too short. However, after I had an inevitable crash, I hit upon this solution. The two screws securing the boom seemed to me way too flimsy, and after the crash one was toast, so I removed the screws and replaced with a 9.5-12mm clamp from our local harware store. Not only does it hold the boom better, thus avoiding twisting, it also means you can move the boom further in, to fix the control rod length problem. Have tested it and it flys fine.
Ianh is offline
Old 03-19-2010, 03:30 AM
  #71
velojet
velojet's Avatar
Default Holding the boom
Originally Posted by Ianh View Post
... I removed the screws and replaced with a 9.5-12mm clamp from our local harware store. Not only does it hold the boom better, thus avoiding twisting, it also means you can move the boom further in, to fix the control rod length problem. Have tested it and it flys fine ...
Very nice solution, Ianh (and superb photos). I applied a much more primitive solution and simply Gorilla Glued the boom in.
John V
velojet is offline
Old 03-19-2010, 08:47 PM
  #72
Ianh
You must have a half decent camera to take pics like that - very nice!
My only concern is the weight (I am fanatical about it) and the rather crude look but I am sure it does the job very well.
Is your Wing Dragon "standard" or "improved"? How about a pic?
I have just got in from flying mine with the 70% area flapped wing and the latest lightweight "mid set" tailplane.
As it has no control rods I don't mind if the boom moves a bit, in fact I twist it to make sure the tailplane and wing are lined up correctly.
At 16oz all up its performance, both power on and power off, is spectacular.
Old 03-20-2010, 06:34 AM
  #73
Ianh
Default Wing Dragon
Well ok its a standard Wing Dragon 3 but it has a 2.4GHz radio and a BM2408-21 Brushless outrunner. Its the one from Banana Hobby, yes I know I've seen all the threads about them, but tbh I had little to no problem with them, it also came with the floats for landing on water (not tried this yet), the only difference to what was in the ad was they shipped a 7 cell 8.4v 1000mAh NIMH battery and not the stated 7.4V 1300mAh Li-Po. Anyway weight wise the clamp was 10g and the pilot they include is 14g which i dont use, so it sorta wins, and i dont really think it looks crude but hey, it works
Ianh is offline
Old 03-20-2010, 06:58 AM
  #74
Airhead
Redneck Member
Airhead's Avatar
Wow,
you guys have some impressive stuff....
Airhead is offline
Old 03-20-2010, 07:02 AM
  #75
Airhead
Redneck Member
Airhead's Avatar
[QUOTE=Ianh;702500]I have been reading this forum with keen interest as I am learning to fly with one of these planes. I too had the same problem with the control rods being too short. However, after I had an inevitable crash, I hit upon this solution. The two screws securing the boom seemed to me way too flimsy, and after the crash one was toast, so I removed the screws and replaced with a 9.5-12mm clamp from our local harware store. Not only does it hold the boom better, thus avoiding twisting, it also means you can move the boom further in, to fix the control rod length problem. Have tested it and it flys fine.
Terrific idea.... I also had the same situation with control rod lengths...
Airhead is offline
Quick Reply: Wing Dragon/Wing Dragon 4/Begin-Air Series Planes Tips & Tricks
Page generated in 0.11710 seconds with 23 queries
