E-Sky Flight simulator
Old 07-13-2008, 09:29 AM
ratrod
ratrod's Avatar
Default E-Sky Flight simulator
I have a E-Sky Simulator.
I was wondering if anyone can give me the settings for the heli. I cannot get it set up right.
I got a heli & I need this help bad. I blew the thing apart today, I know they are not the same but it will get me use to the controlls.
I have no problem setting it up for the plane. I just cant get it set for the heli. I cant even get the throttle on the corect stick.
So I hope some one out there can give me the settings & tell me what boxes to check.
Thanks Rat Rod
I will be off to the hobby shop tomorrow to give up more $$$$$$
ratrod is offline
Old 07-18-2008, 04:41 AM
ratrod
ratrod's Avatar
Default E SKY Flight Simulator
Out of everyone who has read this thread,no one has any help?
I would really like to get some practice.
The settings are channel #s 1-8 for
Rudder
Elevator
Aileron
throttle
tail
nick
roll
pitch
And it has 2 boxes to check or not next to each control.
INV or EXP
I sure hope I can get some help.
Thanks Ratrod ?? ??
ratrod is offline
Old 07-18-2008, 03:15 PM
bassplayinDude
Duplicate your settings for the top 4 options (Rudder thru throttle) into the bottom 4 options. Then try to fly a heli. Note which ones are going the wrong way, then go back into the setup screen and click the reverse checkbox for the ones going the wrong way.
bassplayinDude is offline
Old 07-18-2008, 05:04 PM
ratrod
ratrod's Avatar
Thanks, I tryed that but no go. When I go to calibrate only 1-4 move?
What do the boxes mean INV- EXP? I have checked 1 or both to try & none at all.
In calibrate mode it shows throttle on the left moving channel 3. So I tryed to put 3 for throttle & it still is on thr right sticl for the alieron.
Thanks.
Getting fustrated.
ratrod is offline
Old 07-18-2008, 08:37 PM
bassplayinDude
INV = inverted, just like switching from Normal to Reverse on your Tx. EXP = exponential, which allows your controls to be less sensitive around mid-stick.
Old 07-18-2008, 10:55 PM
smokejohnson
smokejohnson's Avatar
This is watt works for me
Rudder: 4
Elevator: 2
Ailerons: 1
Throttle: 3
Tail: 4
Nick: 2
Roll: 1
Pitch: 3
The INV box is checked on them all. I can switch back and forth between planes and heli's with out recalibrating. Hope this helps.
Edit: When I do calibrate the box the only bars that move are channels 1-4 but it works when flying the helis. I'm not sure watt the calibration bars on channels 5-8 are for.
smokejohnson is offline
Old 07-19-2008, 05:31 AM
ratrod
ratrod's Avatar
James,
Thanks for the shot. It still don't work.
Setting it up like that the throttle is still om the right & it's when you normaly would move the heli to the right. It does not move to the right it just lifts and rolls over into the ground.
I sure wish I could get this thing to work. I sure could use some practice that wouldn't cost me $50-100 $$$
Thanks again.
I will try to check & uncheck the boxes
ratrod is offline
Old 07-19-2008, 05:53 AM
ratrod
ratrod's Avatar
James,
Thanks so much. I went back in after posting a reply & guess what???
My settings the first time didnt take effect & it went back to my old ones.
I re entered them & now it works fine. Thanks very much.
One more question.
I can fly this thing pretty good the first time out. Flips rolls 3D.
Just trouble landing.
I cant even get my real Heli to hover with out loosing control. I have smashed it up so much. Why does it appear like I kind of got some experiance on the simulator??
If I take my real one out right now I will be going BACK to the hobby shop in the morning. & I wont even use 1/4 of my battery in the process?
Ratrod
ratrod is offline
Old 07-19-2008, 05:56 AM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
Cause FMS has a....not so advanced physics engine.
SkunkyMagoo is offline
Old 07-19-2008, 11:56 AM
smokejohnson
I actually don't fly heli's except for on the sim so I can't say watt the differences are. I do know I run into the same thing on flying 3D with my planes. I look like a pro on the sim ...but IRL I can barely hold a hover for 5 seconds :o. Like Marc said FMS is lacking in the physics department.
Have you heard of or taken a look at the RADD method for learning to fly RC helis?
Gofer303
Beginners - Helis
08-21-2008 04:28 AM
Dravenm4
04-26-2008 04:17 AM
zzz
Foamies
02-05-2007 04:42 AM
ploomb
General RC E-Heli Talk
8
12-22-2006 09:02 AM
ploomb
Beginners - Helis
11-26-2006 05:37 PM
Quick Reply: E-Sky Flight simulator
Page generated in 0.11281 seconds with 13 queries
