E-Flite EC-1500
Old 08-29-2019, 05:45 AM
WVrailfan
WVrailfan's Avatar
Default E-Flite EC-1500
I picked up this new plane from E-Flite. I got it because it looks like a modern twin turboprop cargo plane, but it is designed to also handle most aerobatics.
The plane looks somewhat like a C-27J, but E-Flite is quick to point out that it is not a scale model of any particular plane. Close inspection will confirm that it deviates from scale in many areas.
It is a twin with 650Kv motors which can fly powered by 3 or 4 cell batteries. On 4 cell it has plenty of power and vertical is nearly unlimited. It comes with counter rotating five blade scimitar style props. The control surfaces are large, much larger than if the plane were scale, so aerobatics are well within the this plane's flight envelope. The plane is equipped with an operating cargo ramp at the rear of the fuselage. It also includes a nice set of bright LEDs for those after sunset flights.
So far I am very pleased with the plane. I had a setback when I first got it, but it was my error and I have since remedied the issue and have about 20 flights with the model. Learn from my mistake, if you get one of these, make sure the props are on very tight.
The plane flies great. It is rock solid and very stable. It also has gobs of power, so if you get board with scale flying you should be able to do some serious barn storming.
My one and only complaint is that it doesn't have retracts, but it doesn't take away from the fact that this flies outstanding.
Jim
ID:	187632   Click image for larger version
ID:	187633   Click image for larger version
ID:	187634   Click image for larger version
ID:	187635   Click image for larger version
ID:	187637   Click image for larger version
ID:	187638   Click image for larger version
WVrailfan is offline
Old 09-02-2019, 09:28 PM
Sounds like a nice plane. I imagine you could add retracts if you wanted to.
AEAJR is offline
Old 09-04-2019, 05:53 AM
WVrailfan
WVrailfan's Avatar
Old 09-26-2019, 07:32 PM
WVrailfan
WVrailfan's Avatar
If you like your twin a little more scale looking, some gray paint and decals from Callie Graphics and, voila!
ID:	187654   Click image for larger version
ID:	187655   Click image for larger version
Old 09-30-2019, 03:21 PM
Blade_Flyer
Blade_Flyer's Avatar
This is an awesome plane. I've seen a lot of complaints about the lack of retracts, but I like the fact that the gear is solid and looks fine in the air and on the ground. It flies well off of the grass no matter if it's a little tall sometimes. I like the cargo door. Attached is a video I took from the nose and from the cargo bay during an air drop.
Blade_Flyer is offline
dereckbc
11-11-2017 07:52 PM
franklin_m
06-09-2017 09:22 PM
Flite Brothers
Multi-Rotors
11
06-27-2015 05:16 AM
Flite Brothers
06-05-2015 10:37 PM
FlyingMonkey
Off Topic Chit Chat
66
04-04-2011 05:58 AM
Quick Reply: E-Flite EC-1500
Page generated in 0.10697 seconds with 26 queries
