New to Electric Flight - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-19-2020, 04:02 PM
dasintex
dasintex's Avatar
Default New to Electric Flight
Quick Question; the higher KV Motor the larger the Props that can be used?
dasintex is offline
Old 01-19-2020, 09:44 PM
dasintex
No its the other way round.
kV means the motor revs per volt applied so a 950 kV motor will turn off load at battery volts x 950. For example with a 3s LiPo that would be 11.1 x 950 = 10,500 rpm. A 3000 kV motor would turn at 11.1 x 3000 = 33,000 rpm.
Brushless are basically constant speed motors so the rpm at maximum amps is only about 15% lower than at no load.
Too big a prop on a brushless will cause it to try to take too many amps and likely burn out the ESC and/or the motor.
Old 01-20-2020, 11:16 AM
Originally Posted by dasintex View Post
... the higher Kv motor the larger the props that can be used?
Kv says very little about max.power or max. current a motor can handle, nor about max. torque. A 1:1 train motor and the motor in your toothbrush or in a bedroom appliance can have the same Kv.
Motors have only one Kv ,it is the velocity konstant, a physical property, expressed in the unit rpm/volt. Kv is not a rating, not a figure of merit (explanation).
A Kv=1000rpm/volt motor on 10volt and a Kv=2000rpm/volt on 5volt will give same (no_load)speed of 10,000rpm, provided the motors can handle the current and power.
It's all about what the motor wants to do versus what the motor can do.
Kv matches rpm and voltage, there's nothing more to it.
  1. Want
    Kv and voltage determine how fast motor wants/tries to run
    (rpm_noload = voltage Kv, or, in other words, Kv = rpm_noload / voltage.)
  2. Current
    RPM and prop determine torque, which in turn determines current
    (current = torque Kv, in SI units!, or proportional to Kv ).
  3. Can
    Max.current and max.power determine whether that battery/motor/rpm/prop combo can run without going up in smoke.
An engine tries to keep a constant torque: as load goes up, rpm goes down.
An e-motor tries to keep a constant rpm, no matter the load: as load goes up, torque must go up, and therefore current goes up.
Old 01-20-2020, 11:18 AM
Below an excellent quote about Kv and motor selection.
From
brushless motors Kv?
The reason I suggest picking Kv last, is that prop choices have bounds - the diameter that will physically fit and the minimum size that can absorb the power you want. On the other hand, combinations of voltage and Kv are much less constrained - at least before you purchase the components.
So Kv is not a figure of merit, in that higher or lower is better, it is simply a motor characteristic that you exploit to make your power system do what you want, within the constraints you have, e.g. limited prop diameter, if it's a pusher configuration, or if you already have a bunch of 3S packs and don't want to buy more, and so on.
Minor lay-out changes by RvS
Old 01-20-2020, 11:24 AM
Some well-structured reading for rainy/windy days, including two online books, and some handy e-tools as well.
Will save you, and us a lot of questions, and probably a crash or two. Notably the 'what went wrong?' kind of questions
E-flight primer and tools - RCG
And pleasepleaseplease, do your RC equipment, wallet, ego, battery, controller, motor, house/garage/car a big favour ... get a watt-meter.
A watt-meter will more than pay for itself, will save you at least one fried motor and one fried controller. Will also help you finding the best setup.
Keep battery-/-watt-/multi-meter wires short!
too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG
Flite-Metal
277
01-27-2020 02:30 PM
01-09-2017 02:23 AM
write2dgray
09-27-2012 09:59 AM
raitheslacker
09-17-2012 08:13 PM
Quick Reply: New to Electric Flight
Page generated in 0.09681 seconds with 15 queries
