Removing Blade CP Grips - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-31-2006, 08:02 PM
IowaHeli
Default Removing Blade CP Grips
I need to remove the blade grips from my CP. I removed the rotors and have attempted to remove the two allen bolts (one on each side) that secure the grips, but have been unsuccessful. Are they on there really tight (and threadlocked perhaps) or is there some other way to remove them other than placing an allen wrench into each one and turning the opposite direction? The wrenches strip out and the bolts don't budge.
IowaHeli is offline
Old 03-31-2006, 08:18 PM
cooperd
Mine was really tight, just use two allen wrenches and some muscle. May be threadlocked. Use wrenches that aren't worn or rounded.
cooperd is offline
Old 03-31-2006, 09:04 PM
bert269
my stock blade was the same...But I did manage to get the one out...the other one is still stuck....with closer investigation is looks like it's 'rusted'? Imagine that....I mean I'm not flying a submarine here, it's suppose to be a heli...How would it be rusted tight? till today I have not managed to get them apart, so I went and bought a whole new head-shaft, hardware, spacers, etc - to fix the 'collective pitch problem' because mine was wrongly assembled.
thanks
bert269 is offline
Old 03-31-2006, 09:07 PM
bert269
I was afraid of clamping the shaft in anything else than my hands.....I even tried grabbing it with paper and cloth inside the wrenches - no luck...because damage to it was just around the corner...
bert269 is offline
Old 04-01-2006, 02:37 AM
t. edwards
Chuck the shaft in a drill to hold it to take out the 2nd allen head. Tom
t. edwards is offline
Old 04-01-2006, 10:41 AM
Will Hicks
Dealer
Will Hicks's Avatar
The screws are threadlocked. Carefully apply heat on the screw head, with a soldering iron, for a few seconds and you'll be able to remove the screws.
Once you remove one screw, it'll be necessary to safely hold the shaft securely while removing the other. I use a vise fitted with hard rubber jaw protectors to hold the shaft.
Will Hicks is offline
Old 04-01-2006, 10:37 PM
flypaper 2
flypaper 2's Avatar
I got the one screw out, found a piece of piano wire that went in the hole where I took the screw out, then hammered the sucker out.
flypaper 2 is offline
Old 04-02-2006, 04:04 AM
skiman762
FFFC
skiman762's Avatar
make sure you check that the bearing washer mod has been done before you put it back together
skiman762 is offline
Old 04-03-2006, 08:01 PM
IowaHeli
I gave up on using the cheapo elbow wrenches and purchased two quality sets of allen wrenches. The bolts holding the grips came out with ease with the right tools.
On reassembly, I'm having trouble getting both bearings into the grip. On the "finger" end of the grip, you put a spacer, then two bearings touching each other. Any tips on how to get both bearing in there? I can get one in, but not two.
IowaHeli is offline
Old 04-03-2006, 09:14 PM
Will Hicks
Dealer
Will Hicks's Avatar
The grip set that uses the short brass spacer is for the dual bearing units. If you have purchased a set of grips and the spacer is silver, you need the other set.
Old 04-03-2006, 09:19 PM
IowaHeli
Ah, that probably explains it. I'll check it tonight, but I believe the grip I purchased does include a silver spacer. I own a Blade CP, but purchase parts for the E-Sky Honey Bee CP2, since they are cheaper. Perhaps the Honey Bee uses the single bearing grip??
IowaHeli is offline
Old 05-04-2006, 06:29 AM
jimmi
The best way to get your blade grips out is I used to use that wrench they supplied then bought me another better one but still no good fit. I went to my allen wrench set, I have 2 sets I mm and one standard size. I use the millimeter wrench for my blade grip and they work great. The standard size they seem to slip and you cannot get enough bite to get them out. When you put them back in you need to put one large washer then a small washer to start. Inbetween the head it needs 1 smaller washer on each side and when putting the last screw in it needs another large washer and a smaller washer for the blade grips. Hope that helps. Jimmi
They say its mind over matter but if you don't have a mind it doesn't matter
jimmi is offline
Lymph
E-Flite Helicopters
33
08-12-2009 01:06 PM
NUMB-LOCK
Beginners - Helis
04-19-2007 05:36 AM
Flyborg
Beginners - Helis
01-04-2007 04:40 AM
rmbler
02-01-2006 03:47 AM
rmbler
8
01-26-2006 06:19 PM
Quick Reply: Removing Blade CP Grips
Page generated in 0.11556 seconds with 15 queries
