Help with My Blade CX-2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Micro Sized Electric Helicopters Discuss micro and mini sized electric rc helis in here
Old 06-09-2007, 06:49 PM
dashley
Default Help with My Blade CX-2
Hi,
I am replacing both motors in my E-flite Blade CX-2 and got the left and right motors mixed up.
Could anyone give me a rule for which is which?
A rule like "The motor with the gear closer to the motor body is the left/right motor" would be all I need.
It was a dumb rookie mistake. I can't believe I did it.
I could put the heli back together and if I guessed wrong correct it, but I'd prefer to reassemble only once.
Thanks.
dashley is offline
Old 06-09-2007, 07:03 PM
the motor with the gear closer to it is on the left as you look at it from the top or bottom
Old 06-09-2007, 08:35 PM
TheBum
Still in training
One way to remember (I just replaced mine too) is first to remember that the connectors on the 4-in-1 are in the order of the rotors, i.e. the top connector is for the top rotor and the bottom connector is for the bottom rotor. Add to that the fact that the leads on the motors are the same length, and you'll find that if you try to plug the right motor onto the lower connector, it won't reach, which means that the right motor must drive the upper rotor, so it has to be the one with the gear farther from the inner workings. It's kind of a twisted bit of deductive reasoning, but it works.
TheBum is offline
Old 06-09-2007, 10:44 PM
Sentertainment
Hobbyist/Web Developer
Sentertainment's Avatar
which side you put it on shouldn't matter to be honest.
also, when plugging them in, just make sure each blade spins properly when moving the trim on the remote.
Sentertainment is offline
Old 02-28-2011, 01:57 PM
m505matt
OMG I crashed it!!!
Im new to this so here we go!!! Does anyone have any ideas for a homemade tailboom mount for the blade cx??? THanks ahead of time
m505matt is offline
merctech
Beginners - Helis
24
03-28-2011 04:19 PM
pappy60
E-Flite Helicopters
29
12-27-2007 08:23 PM
Spankys Flying
Beginners - Helis
02-15-2007 02:27 AM
quailbird
Beginners - Helis
11
01-26-2007 10:41 PM
cdnmoose
Beginners - Helis
11
11-26-2006 02:55 AM
Quick Reply: Help with My Blade CX-2
Page generated in 0.08680 seconds with 13 queries
