Need help with brushless ESC - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-08-2011, 06:50 PM
rc_flyboy1
Default Need help with brushless ESC
I have just bought a Neodym 480 1120kv brushless motor. It calls for a 30A to 45A ESC. I will be using a 3 cell 2200mAh li-po (11.1v) and a 11x5.5 prop. Will a 30A ESC do the job or do I need to go higher? I'm new to electric and I need as much help as I can get. I am using this setup on a power pod for a sailplane. Thanks!!!
rc_flyboy1 is offline
Old 01-08-2011, 07:40 PM
dumo01
dumo01
dumo01's Avatar
The only way to be sure is get a watt meter and measure the current draw with your set up, but the Neodym motor looks similar to the heads Up Power 480:
http://www.headsuprc.com/servlet/the...80-Plus/Detail
At least on Jeff's setup, using an 11x 5.5 prop had a current draw of 30 amps. if your results are similar that would leave very little to no safety margin.
I would go 40-45 amp, the extra capacity will not do anything bad.
dumo01 is offline
Old 01-08-2011, 07:44 PM
rc_flyboy1
Thanks! I will go with a 45A. I've been looking at one but didn't know if I needed it. Thanks again!!
Old 01-08-2011, 11:19 PM
Never hurts to have a little too much capacity.
Old 01-09-2011, 12:35 AM
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
second that
HeliScRapYard is offline
Old 01-10-2011, 01:32 AM
starcad
Model Designer
starcad's Avatar
I personally like overkill myself. You should be spot on with the 45A and may have a bit let over. At least it won't hurt to use the 45A.
starcad is offline
02-25-2018 11:51 AM
d&mrc
03-16-2011 08:35 PM
bah7566
02-27-2011 12:07 PM
Devil_Inside
01-06-2011 06:03 PM
mentor
12-24-2010 12:27 AM
Quick Reply: Need help with brushless ESC
Page generated in 0.09360 seconds with 11 queries
