e-starter climbing - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
e-starter climbing
Old 04-29-2006, 02:53 PM
FP-74
Default e-starter climbing
Hello! This topic has probably been hit upon before but here goes.
my e-starter, stock, with eps 400 power system flew (barely) but straight and level. i put a 300 outrunner and a lipo LOTS of power but it climbs like crazy. it is very slightly tailheavy (it also was with the stock set-up) would that make it climb so bad? i tried trim on the radio but still climbs.
elevator looks real level with stab. would a change in the thrust angle help?
i found a stick mount for the outrunner so i used the stick from stock power system. if you need more specifics let me know and i'll post them , Thanks!
FP-74 is offline
Old 04-29-2006, 03:37 PM
I would think you need to move your cg forward a tad to balance it. That big of a weight diff is going to change it, makes it tail heavy and yeah with that power she'll climb all day...
I know on my Beaver I had to do the same when I went with the 400 xt and lipo, from the geared, brushed and Nimh batts. After I added a tad bit of weight in the nose to get that balance back she flies great now.
Old 04-29-2006, 03:44 PM
Twmaster
Registered User
Twmaster's Avatar
A small amount of down thrust won't hurt. Also as Bill mentioned move some weight forward so it balances correctly. Add weight only as a last resort.
Twmaster is offline
Old 04-29-2006, 03:51 PM
I didn't have to add much, 1 1/2 in washer from the toolbox was all! I moved the servos and receiver forward a bit and cut out about a 1/2 inch from the front of the battery compartment to move it forward as well, plenty of room in the Beav, don't know about the E though.
Old 04-29-2006, 06:02 PM
Doppelganger
Think I can fix it?
I've had a couple of the these planes. The built in thrust angle isn't sufficient for brushless flight. You'll have to change the thrust angle and add weight. Just like Bill said. Change the thrust angle first. Then get your cg slightly nose heavy. You should be good to go after that.
Doppelganger is offline
Old 04-29-2006, 08:23 PM
t. edwards
The other way to "fix" this is in the tx. Mix some elevator with the throttle. Tom
t. edwards is offline
Old 04-30-2006, 01:50 AM
FP-74
thanks everyone for your replies to my question! i've already fixed the cg and i'll add alittle thrust angle. now if the wind would let up some i'll get to try it!
thanks again!
FP-74 is offline
Old 04-30-2006, 01:54 AM
Good deal FP, it's been crazy windy here today as well. Where are you?
Old 04-30-2006, 01:55 AM
Doppelganger
Think I can fix it?
Doing that basically will have him flying around in sort of a "flaps" mode. It sacrifices airspeed for level flight. Better to adjust the thrust angle.
Old 04-30-2006, 03:00 AM
t. edwards
Steve,
Yes, in a way it's a crutch. But you can use it as a fix at the field and get it to fly level at all throttle settings without rebuilding the plane. Adding reflex on the ailerons can also be effective and on trainers frquently makes them fly better. Just another option, Tom
Old 04-30-2006, 03:50 AM
FP-74
I'm in Conn. and i've added alittle down thrust maybe early tomorrow morning it will be calm enough (i love nice quiet electrics!) thanks again!
Gary
FP-74 is offline
Old 04-30-2006, 03:54 AM
Best of luck to ya... Let us know how it works out.
Old 04-30-2006, 03:56 AM
FP-74
thanks, will do!
FP-74 is offline
Old 04-30-2006, 05:45 AM
Doppelganger
Think I can fix it?
Steve,
Very true.
Old 04-30-2006, 12:14 PM
FP-74
YEAH BABY! now that's flyin'! dead calm outside, put the sunrise to my back, hand launched and off she went . a couple of clicks of up trim and she flew great! thanks all for your advice-worked like a charm! now i have to work on my lipo collection!
Gary
FP-74 is offline
Old 04-30-2006, 01:53 PM
Glad to hear it bud!
Old 04-30-2006, 02:44 PM
Doppelganger
Think I can fix it?
Good job Gary! Glad it all went well.
Old 04-30-2006, 03:05 PM
Twmaster
Registered User
Twmaster's Avatar
WooHoo!!!
Twmaster is offline
Old 04-30-2006, 06:51 PM
luisfc1972
did you record a video?
luisfc1972 is offline
Old 04-30-2006, 07:42 PM
FP-74
no-no video... all by myself.went back out later 3rd flight put it in a tree :-(
but it's all repaired now :-)
gotta watch out for them pesky jumpin' trees!
FP-74 is offline
Old 04-30-2006, 11:25 PM
t. edwards
Not a kite eating tree I hope. Tom
Old 05-01-2006, 01:23 AM
Doppelganger
Think I can fix it?
Your trees jump. Here the ground jumps. Just drives ya nuts!
Old 05-01-2006, 03:44 AM
A strange Phenomena indeed... Here the Football goal posts move rather quickly... Powerlines area lot closer than they appear too
Old 05-01-2006, 05:57 AM
Doppelganger
Think I can fix it?
Hmmmm, do we all drink from the same well?
Old 05-03-2006, 05:09 PM
Heightisgood
New England Flyer
Heightisgood's Avatar
Default Hangin' in a tree
Which tree? I've probably in it the same one :p
<Jeff
Heightisgood is offline
Quick Reply: e-starter climbing
Page generated in 0.15368 seconds with 12 queries
