How to set low flightpack voltage alarm on Turnigy/FlySky i6 Transmitters - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-08-2016, 11:23 AM
Paul80
Default How to set low flightpack voltage alarm on Turnigy/FlySky i6 Transmitters
Hi all
A quick question I hope
I have one of the Turnigy i6 Transmitters which I use with both Turnigy iA6B & iA10 Receivers and have the correct Flight Pack Voltage Sensors TGY-CVT01 for the i6 & TGY-CVT01 for the i10
Both sensors read the and display the flight pack voltage when I select IntV2 from the sensor list but I get no low voltage alarm
If you watch this video showing a FlySky i6 transmitter working with the Voltage sensor and giving a low voltage alarm the voltage sensor sellected as can be seen on the Transmitters screen is ExtV2 which is a setting mine does not have.
https://www.youtube.com/watch?v=cPWt...TO92Ug&index=2
Is this only an option on the FlySky Version, I thought they were the same or is it possible to get the Turnigy to give a low voltage alarm with their sensor. If yes how do you set it up to do so.
I have tried both the Turnigy Firmware and the Hacked FlySky 10 channel firmware and do not get an option for Extv2 in the sensors list with either.
Thanks for any help with this
Paul
Paul80 is offline
Old 05-08-2016, 05:08 PM
Paul80
Well for some bizarre reason as seen in the photo below the option for ExtV2 suddenly appeared
I put these test values in the RX Battery setup page and it appears to work fine now giving an audible warning at alarm position
Very Bizarre
Paul
Paul80 is offline
ghost1
11-24-2013 05:05 PM
Pat Masac
Batteries & Chargers
09-14-2013 05:25 AM
propduster8
12-13-2012 01:42 PM
FlyingBrick50
Heads UP RC discussion
11-21-2011 10:18 AM
Quick Reply: How to set low flightpack voltage alarm on Turnigy/FlySky i6 Transmitters
Page generated in 0.04671 seconds with 12 queries
