Mini shaft / rod straightener ? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-02-2018, 04:22 PM
Default Mini shaft / rod straightener ?
I am trying to find if there is such a tool as a shaft / rod straightener ?
I am fed up with collecting heli shafts ... motor shafts .... and the like that have a slight bend ... I have straightened a few but they still have a slight 'wobble' when run up.
If there is a tool out there that can straighten these - it would be a tool from heaven for me !
Needs to be able to straighten up to 6mm steel rod ...
Old 11-02-2018, 11:06 PM
Maybe this might Help Nigel, after straightening the shaft, roll it on a piece of glass panel to check for straightness.
Old 11-02-2018, 11:14 PM
With Nitro Engines to Straighten out the Crankshaft where the prop attaches to, I chuck the Treaded part of the Crankshaft to a Drill press, attach a dial indicator to the drill press with a Magnetic base, put the dial indicator shaft at the lowest part of the crank, check the run out, and tap the crank shaft with a small mallet to straighten it, and keep checking and tapping the crank until its straight
Old 11-03-2018, 12:10 AM
Past President of PSSF
I have used a drill press as a arbor press. I just supported both sides of the shaft, and then used the drill press chuck as a controlled force. I could push just a little more at a time until it was straight.
The rolling the shaft on glass is a good way to find the high spot.
Wildflyer is offline
02-21-2015 04:03 AM
Rich B
01-16-2015 07:26 PM
golfryan
03-09-2012 06:29 PM
hayofstacks
Crash and Safety Forum
03-05-2012 12:07 AM
All American
02-08-2010 09:17 PM
Quick Reply: Mini shaft / rod straightener ?
Page generated in 0.08720 seconds with 13 queries
