bubble filler - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
bubble filler
Old 05-08-2008, 07:51 PM
worldraft
worldraft's Avatar
Default bubble filler
I'm at the point were I need to do some filling but I'm not sure how to do this, what product to use to make my filler.
Jean
worldraft is offline
Old 05-08-2008, 09:23 PM
Bub Steve
Bub Steve's Avatar
Jean
Have you thought about Epoxy&MicroBallon's?? bub, steve
Bub Steve is offline
Old 05-09-2008, 01:32 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Fill'er Up?
Hello Jean,
Depends on what you're filling. For foam, many builders use lightweight spackle, I've tried "Red Devil" and it seems pretty good. There are many other brands available.
On balsa, I've used microballons and epoxy, it works well but is hard to sand and if you overdo the epoxy, it can be heavy.
I sometimes make my own "mix" of balsa filler from balsa sanding residue (dust) and Titebond wood glue. It can be thinned with water, also.
Just a couple of ideas!
Ron
Sky Sharkster is offline
Old 05-11-2008, 10:23 PM
worldraft
worldraft's Avatar
Thanks to the both of you, And by the way I'm using balsa. I was thinking of wood gloo, but When U say Epoxy, do you meen epoxy glue, or epoxy resin?
Old 05-12-2008, 12:47 AM
Sky Sharkster
Default Which Adhesive?
Hello Jean,
The epoxy I use is a 2 part adhesive, like this;
http://www.zapglue.com/Epoxy.html
http://www.sigmfg.com/IndexText/SIGEG001.html
There are different formulas, usually "5 minute" curing (Devcon in a popular brand) is for field repairs and the 30 minute type is for general building, often used with fiberglass tape or carbon fiber as a reinforcement.
Here's a link to the most common adhesives for hobby use;
http://www.airfieldmodels.com/inform.../adhesives.htm
Ron
Grasshopper
Warbird Electrics
460
07-09-2008 08:19 PM
Ringwood
General RC E-Heli Talk
02-12-2008 07:48 PM
Balr14
Foamies
09-04-2007 07:55 AM
Larry G
ParkFlyers
07-19-2007 12:50 AM
Quick Reply: bubble filler
Page generated in 0.09063 seconds with 13 queries
