Expoxy - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Expoxy
Old 08-10-2005, 06:01 PM
Douglas
Default Expoxy
I'm using 2 part 5 minute epoxy in a syringe from Home Depot. I'm careful that both parts are equal before I mix.
The batch I used last night on a balsa sailplane was from a new tube. It hasn't cured yet, over 12 hours! It's a tacky plyable consistancy.
Can I just add some hardener to the surface, or do I need to scrape everything away and try and start over?
Thanks,
Douglas
Douglas is offline
Old 08-10-2005, 06:13 PM
You need to clear all of it and start over again. Age affects epoxy greatly in my experience. It might be old and no-good anymore.
Do a test batch before using it again.
Old 08-12-2005, 05:34 AM
tdonily
Village Idiot!
I have some epoxy that I used in making model yachts. Is West Systems brand overkill on an aircraft?
tdonily is offline
Old 08-12-2005, 02:05 PM
Nope lots use West systems brands on planes....they are excellent.
Old 08-15-2005, 02:48 PM
RysiuM
RysiuM's Avatar
Scrape and then clean the wood. The easiest way is to brush and wipe the wood with acethone. Takes out uncured epoxy without a trace. Leaves the clean wood ready for the second attempt.
RysiuM is offline
Old 08-17-2005, 04:06 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Epoxy mixing
Epoxy mixes can vary a lot. Have you used the same batch before with good results? Maybe the whole container is bad. Also, believe it or not, if there's even a trace of oil on the surface you mix it on, it won't cure. Last, weather. Too humid? too hot/cold. I find "Sig" and "HobbyPoxy" the most consistant from batch to batch. Sky Sharkster
Sky Sharkster is offline
Page generated in 0.09850 seconds with 12 queries
