Motors running backwards? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-29-2008, 05:03 PM
JGMM_BC
In over my head?!
JGMM_BC's Avatar
Default Motors running backwards?
I know this is going to sounds stupid... But! I just finished setting up my motors on my OV-10. I am using E-Flight 400s and Phoenix ESCs. All the wires are correct, Black to Black, White to White, Red to Red. When I am facing the motors they turn clockwise. This is correct, right? The reason I ask is that when I put the props on, they are pushing air forwards...
Any ideas?
JGMM_BC is offline
Old 06-29-2008, 05:06 PM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
Just swap any two wires and they will switch direction. No problem.
SkunkyMagoo is offline
Old 06-29-2008, 05:18 PM
JGMM_BC
In over my head?!
JGMM_BC's Avatar
Default New Info...
OK, I was looking at the setup again and realized that I have 6X1 gears on the motors. This would mean that the motors would turn the shaft in the opposite direction due to the gears right?
By any two wires, you mean the red and black? I am using brushless motors...
JGMM_BC is offline
Old 06-29-2008, 05:19 PM
SkunkyMagoo
Newborn Rotorhead
No, literally any two. But if you prefer black/red go for it.
Old 06-29-2008, 05:21 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Marc is correct on a 3 phase AC motor swaping any two motor leads will reverse the direction of rotation.
rea59 is offline
Old 06-29-2008, 05:22 PM
smokejohnson
smokejohnson's Avatar
Marc is speaking the truth. On a brushless motor you simply swap any 2 of the 3 wires going to the motor from the esc and it will reverse rotation of your motor. The colors really don't matter.
smokejohnson is offline
Old 06-29-2008, 05:29 PM
max2112
max2112's Avatar
Default yep, what he said.
Skunky is exactly right. Swapping the connection between any of the 3 motor-to-ESC wires will change the direction of spin for your motor.
The gear box shouldn't matter.
Another helpful bit of info that might help is that the vast majority of propellors have the size & pitch numbers stamped on the front of the blade. Meaning that the "11.4x7" faces the direction of travel.
max2112 is offline
Old 06-29-2008, 05:35 PM
max2112
max2112's Avatar
Man I gotta learn to type faster!
4 accurate replies in the time it took me to peck out my meager offering!
All I can say is: "Yeah, what they said!"
max2112 is offline
Old 06-29-2008, 07:05 PM
pilotpete2
Pilotpete2
pilotpete2's Avatar
Since you have a CC Phoenix controller, you also can reverse rotation of the motor in the controller setup real handy if you soldered the wires first, eh.
Pete
pilotpete2 is offline
Old 06-29-2008, 11:50 PM
Laggard
Who's got my six?
Laggard's Avatar
Facing the plane, the prop should spin counter-clockwise.
Laggard is offline
Old 06-30-2008, 12:46 AM
JGMM_BC
In over my head?!
JGMM_BC's Avatar
Thanks for all the input guys... Got it all figured out...
JGMM_BC is offline
Old 06-30-2008, 12:53 AM
smokejohnson
Got any pics John?
Old 06-30-2008, 12:58 AM
JGMM_BC
In over my head?!
JGMM_BC's Avatar
I'll take some tomorrow and post them... Getting close...
JGMM_BC is offline
Old 06-30-2008, 02:41 AM
JGMM_BC
In over my head?!
JGMM_BC's Avatar
Smile Pictures...
Well here she is... The orange props will be coming off after the first few flights... I'm working on the rest of the covering this week. My next real challenge will be the landing gear and the battery placement. The plane is really tail heavy. So much so that I have to put the batteries right up against the forward compartment bulkhead which then interferes with the nose gear control...
JGMM_BC is offline
Old 06-30-2008, 03:28 AM
Bub Steve
Bub Steve's Avatar
JGMM_BC::Get a fresh Black magic marker, they'll look like you bought-um that way, cool plane! bub,steve
Bub Steve is offline
Old 06-30-2008, 04:05 AM
smokejohnson
Nice work John. Keep us posted.
Old 06-30-2008, 10:54 AM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Looking good John
rea59 is offline
FlyingMonkey
Support & Suggestions
8
10-01-2007 12:37 AM
Jetskeeter
Beginners - Helis
07-04-2007 07:56 PM
RickAvery
03-24-2006 07:50 PM
Brian C
03-09-2006 05:51 AM
Faspro
22
10-07-2005 04:56 PM
Quick Reply: Motors running backwards?
Page generated in 0.12674 seconds with 12 queries
