Forsale Excellent Condition - HobbyZone Freedom - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Airplanes - Electric For Sale & WTB Electric Powered RC Planes for sale and wanted in here. Free to buy or sell!
For Sale Excellent Condition - HobbyZone Freedom
Old 01-01-2009, 01:50 PM
cbatters
cbatters's Avatar
Default Excellent Condition - HobbyZone Freedom
Very clean plane that I bought as new-defective and I replaced one of the servos and it works fine now. (Checked out the plane extensively but it has never been flown.) PLane looks brand new.
Note: Although HobbyZone rates this plane as Zone 1, I would not recommend it as a first plane unless you have some experience on a simulator - a bit too fast / aerobatic. (MUCH better for a beginner to start with a slower more stable plane like the HobbyZone Commander II.) I would also suggest covering the lower ACT sensor with electrical tape and using the ACT control on transmitter as a dual rate control. Adding 3 quarters to nose moves CG forward for better balance and reduces tendancy to tip stall.
Comes in original box with all accessories / parts (Plane, transmitter, 8.4V NIMH battery, charger, landing gear, manual, instructional DVD.)
Sells new for $139.00
Hangar clearing time - $54.99 + 15.00 S&H
Only $59.00 + $15.00 S&H
Over 50% off Retail Price
Payment via Paypal from confirmed addresses only
Features
  • Revolutionary Anti-Crash Technology, exclusive to HobbyZone, which actively monitors the plane’s orientation, as it relates to the ground and sky, and cuts the motor, in tandem with giving neutral steering and up elevator, if the plane enters a steep dive. This causes the plane to come out of the dive so the user can regain control. Once pilots gain experience flying, they can increase maneuverability and overall control by turning ACT off via the switch on the transmitter
  • A 3-channel radio system that makes it easier for pilots who are new to RC to teach themselves how to fly with a 3-channel airplane, thanks to ACT. Additionally, the third channel allows for pitch control so that pilots can make tighter turns and have a wider range of maneuvers, as well as the option to make pitch trim adjustments while the plane is in the air
  • A one-box purchase, which means that everything that’s needed to get flying comes in the box
  • A ready-to-fly design that allows users to get in the air quickly after simply attaching the wing pieces and landing gear, and installing the rechargeable 7-cell 8.4V 900mAh Ni-MH battery pack
  • A two-piece, plug-in wing that provides better handling in the wind, smoother flight, easier transportation, and a sleek, swept-wing design
  • X-Port™ technology that allows pilots to use exciting plug-in accessories, such as the Sonic Combat Module™ to dog fight with other X-Port-equipped planes, the Aerial Drop Module™ to drop bombs or a parachutist, or the Night Flight Module™ to fly at night after they’ve become more experienced
  • A powerful 480 motor that permits users to have great climb rate and power while flying their Firebird Freedom
  • Durable, steel wire pushrods for more precise and consistent control
  • A detailed instruction manual and video CD that instruct pilots on the proper techniques and steps that need to be taken to get their Firebird Freedom in the air and flying safely
  • A 1.2 amp variable rate DC peak charger, with LED indicator and trickle charge
  • A soft, resilient rubber nose that cushions the force of impact and decreases damage if the pilot has a hard landing
Overview
Three Channels, Zone 1, Anti-Crash Technology –
New Pilots Get It All with the HobbyZone Firebird Freedom
HobbyZone recently announced plans for the first new plane in 2005 - the Firebird Commander™ 2, with revolutionary Anti-Crash Technology™ (ACT). Another plane will be available soon with ACT, as well – the Firebird Freedom™. This plane will make it easier for new pilots to teach themselves how to fly with a 3-channel system, and then progress on to other larger and faster RC planes in the HobbyZone and ParkZone product lines. Additionally, X-Port technology makes the options for fun endless!
With this plane come many exciting firsts for HobbyZone, which raise the bar for teach-yourself-to-fly, ready-to-fly RC planes:
• A 3-channel radio system in a Zone 1 airplane;
• Anti-Crash Technology in a 3-channel airplane;
• A 2-piece, mid-set, swept, plug-in wing; and
• Rigid, steel wire pushrods to more precisely manipulate the control surfaces.
Specifications
  • Wing Span: 50.0 in (1270mm)
  • Overall Length: 33.0 in (840mm)
  • Flying Weight: 23.0 oz (650 g)
  • Motor Size: 480 Power
  • Radio: 3-channel proportional
  • Trim Scheme Colors: White with blue, red, and black decals
  • Speed Control: Digital proportional ESC/receiver unit
  • Recommended Battery: 7-cell 8.4V 1000mAh Ni-MH comes with the plane (HBZ1013)
  • Elevator: Proportional
  • Rudder: Proportional
  • Throttle: Proportional
  • Approx. Flying Duration: 12 minutes to 15 minutes
  • Approx. Assembly Time: 3 minutes for the plane and 40 minutes or less to charge the battery
  • Transmitter Range: 2500 ft (755 m)
  • Available Frequencies: 6 frequencies on 27MHz
  • X-Port: Yes
  • Charger: 1.2A variable rate DC peak detect - charges 4- to 7-cell packs (HBZ1026)
  • Landing Gear: Steel wire with foam wheels
cbatters is offline
Old 01-02-2009, 05:08 PM
cbatters
cbatters's Avatar
cbatters is offline
Old 01-20-2009, 11:24 PM
cbatters
cbatters's Avatar
Last Chance - $54.99 + 15.00 S&H
Posting on eBay at 9:00 EST tonight and then I will close this thread.
cbatters is offline
livinma1
08-25-2008 02:18 PM
termite
05-16-2008 12:27 AM
cbatters
16
12-10-2007 02:52 AM
kulgan
Company Discussions
04-30-2007 06:36 PM
coloradoz
02-23-2006 08:14 PM
Quick Reply: For Sale Excellent Condition - HobbyZone Freedom
Page generated in 0.09896 seconds with 15 queries
