Conversion Assistance needed - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-27-2011, 06:04 PM
Dr Gyro
Default Conversion Assistance needed
A friend and I are wanting to convert our planes to all electric. He has a 40 gasser (Great Planes we think) and I am assembling a PT 25 Gyro.
Has anyone out there made these conversions and will you be willing to "talk" us through our conversions? Thank You in advance.
Dr Gyro is offline
Old 03-27-2011, 06:34 PM
Been there, done that. Hope this helps!
Old 03-27-2011, 11:49 PM
hillbille
hillbille's Avatar
Nitro airplanes always made me laugh when I read the labels and then groan when I read the price tag. The nitro planes as a "general" rule convert easily to electric, but sometimes do not fly well. The reason behind this is that most are built/designed for tremendous vibration and stress of nitro motors and are "over" structured and re-inforced. Do not misunderstand I like a good deal many of the planes designed for nitro power and own and fly a couple today. The most notable of these is a Skooter II of the quickie 500 ilk.
Nitro planes are ALWAYS UNDERATED for POWER. On the labels for the nitro planes ALMOST every one will have a power preference as well as a "suggested" power for the plane. Both are ordinarily "marginal" with the stated power being extremely inadequate and the larger "suggested" power being marginal at best. Thus a .25 plane for the most part almost requires a strong .40 or better for any performance with that airplane. Most all modlers except this little inside industry joke and overpower their models accordingly.
Electric models and motors for the most part are not part of the industry joke. They actually do perform up to their catagorical standard - for the most part. Some manufacturers overrate their motors for amp draw and kv(rpm) but if they do it is very quickly outed here in the modeling community!!
Motors are rated three ways. Kv - Rpm they will turn PER VOLT SUPPLIED.
AMPs - The amount of electricity it will take to make the motor perform.
(Amps is VERY variable dependent upon the "stress" the motor is subjected to via the prop size and pitch angle used!)
Last a motor is usually measured in WATTS produced for a given setup.
You will want to try to get close to the standard chart to start with and later you may vary this to suit yourself.
Trainer = should be equal to at least 75 watts per aircraft AUW pound.
Sport = Should be equal to at least a 100 watts per AUW pound.
Scale/Aerobatic = should be at least 150 or better watts per AUW pound.
AUW = All Up Weight. Weight of the aircraft READY for flight.
WOT = Wide Open Throttle
Generally speaking a 25 sized motor will produce the thrust equal/better than a .25 glow - usually closer to a .30 to .35 two stroke.
Generally speaking a 32 motor will produce the thrust equal/better to a .40 glow motor - usually closer to a .46 to .50 two stroke.
There is a lot more for you to learn but those are some mere highlights.
I can lost more if you want but most all the things you will need to know or learn are right here in the forum.
Hillbille
hillbille is offline
Old 03-28-2011, 12:00 AM
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
Talking
Hi
This may be of help, Great info
http://www.gregcovey.com/Glow_Conversions_Made_Easy.htm
http://www.gregcovey.com/electric_conversions.htm
Take care
Yours Hank
kenchiroalpha is offline
Old 03-28-2011, 12:02 AM
kenchiroalpha
Hillbille
Hi
Outstanding
Marvelous post
Thanks ever so much
Take care
Yours hank
Old 03-28-2011, 02:07 AM
Default 40 Gasser Power System
1. get a E Flite Power 46, you will have pleanty of power, as these motors are a little under rated.
http://www.amainhobbies.com/product_...rce=google_ext
2. get a 80 amp ESC, its bigger than whats needed, but a larger ESC will stay cooler and last longer. hurry, these sell out fast
http://www.hobbyking.com/hobbyking/s...idProduct=3727
3. you will need a UBEC, here is a 10 amp UBEC from Castle Creation.
http://www.bphobbies.com/view.asp?id...0&pid=B3144784
http://www.wattflyer.com/forums/show...t=ubec+chellie
4. use a APC 12x6 prop. or APC 12x8 prop, better yet, get both to do some testing with.
5. use a 5 cell lipo. 5000mah 25C Rated
http://www.hobbyking.com/hobbyking/s...idProduct=8585
Hope that helps to get you started, use Paypal when shopping over seas, Take care, Chellie
Power 46 Brushless Outrunner Motor, 670Kv
Key Features
  • Equivalent to 40- to 46-size glow engine for planes weighing 4–7 lb (1.8–3.2 kg)
  • Ideal for 25- to 40-size 3D airplanes up to 5 lb (2.2 kg)
  • Ideal for models requiring up to 925 watts of power
  • High-torque, direct-drive alternative to inrunner brushless motors
  • Includes mount, prop adapters and mounting hardware
  • External rotor design—6mm shaft can easily be reversed for alternative motor installations
  • Slotted 14-pole outrunner design
  • High-quality construction with ball bearings and hardened steel shaft
  • Quiet, lightweight operation
Overview
The Power 46 is designed to deliver clean and quiet power for .40 to 46-size sport and scale airplanes weighing 4 to 7 pounds (1.8–3.2 kg), 25- to 40-size 3D airplanes up to 5 pounds (2.2 kg), or models requiring up to 925 watts of power. It’s an especially good match for Hangar 9 .40-size trainers like the Alpha .40 (HAN2450), Arrow .40 (HAN2625) and warbirds like the T-34 Mentor 40 (HAN2425). Also a great match for sport planes like the Ultra Stick 40 (HAN1675 or HAN1690), Seagull Spacewalker 40 (SEA2050), and smaller sport 3D planes like the Twist 40 (HAN2650).
Needed to Complete
60A brushless ESC
4S–5S Li-Po or 12- to 16-cell Ni-MH/Ni-Cd
12x8 to 14x10 prop
Old 03-28-2011, 03:31 AM
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
Man...thats alot of info....Dr Gyro, with hillbillie and Chellie around, you can almost do a conversion like that with your eyes closed! Awesome you guys are the bestest!!
CrimzonRider is offline
Old 03-28-2011, 05:56 AM
Also Dr Gyro Get a WATTMETER, its a must have to check your Amp draw, and to keep everything from frying up here is a inexpensive Wattmeter that will get the job done, there are more expensive wattmeters out there, but these work great. Hope that helps, Chellie
http://www.hobbyking.com/hobbyking/s...dProduct=10080
Old 03-28-2011, 06:06 AM
kenchiroalpha
Exclamation
Hi Chellie
Great advice
And if i may add get a good quality charger or 2 dont scimp on them, imho your TX and your chargers are your most vitaly important purchases
I have Supermate and a Thunderpower chargers in addition to many walmarts and blinkys
Take care dear friend
Yours Hank
Old 03-28-2011, 06:21 AM
Default gyro power system
This power system should work great for your gyro.
1. E Flite power 32
http://www.e-fliterc.com/Products/De...odID=EFLM4032A
2. 60 AMP ESC, hurry, these sell out fast
http://www.hobbyking.com/hobbyking/s...idProduct=2166
3. 10 AMP ubec
4. 4 cell lipo
http://www.hobbyking.com/hobbyking/s...idProduct=9953
Or 3000mah or 4000mah 40C Lipo depending on how much weight your able to carry.
http://www.hobbyking.com/hobbyking/s...dProduct=16183
5. APC 11x6 prop, or bigger if you need it then go to a 11x7 -12x6 but check your amp Draw.
Power 32 Brushless Outrunner Motor, 770Kv
Key Features
  • Equivalent to a 30- to 36-size glow engine for sport and scale airplanes weighing 3.5–6 lb (1.6–2.7 kg)
  • Ideal for 25- to 36-size 3D airplanes up to 4.5 lb (2 kg)
  • Ideal for models requiring up to 800 watts of power
  • Includes mount, prop adapter and mounting hardware
  • Quite, lightweight operation
  • External radial rotor design—5mm shaft can easily be reversed for alternative motor installations
Overview
The Power 32 is designed to deliver clean and quiet power for 30- to 36-size sport and scale airplanes weighing 3.5 to 6 pounds (1.6 to 2.7 kilograms), 25- to 36-size 3D airplanes up to 4.5 pounds (2 kilograms), or models requiring up to 800 watts of power. It's an especially good match for the Gee Bee Tiger Moth, TopFlite DC-3, Phoenix Sonic 25 and 3D airplanes such as the E3D.
Product Specifications
Type:Brushless outrunnerSize:Replacement for a 30- to 32-size glow engineBearings or Bushings:One 5 x 14 x 5mm Bearing, and One 5 x 11 x 5mm BearingWire Gauge:14Recommended Prop Range:11x7 to 14x10Voltage:12–16.8RPM/Volt (Kv):770Resistance (Ri):.02 ohmsIdle Current (Io):2.40A @ 10VContinuous Current:42AMaximum Burst Current:60A (15 sec)Cells:10–14 Ni-MH/Ni-Cd or 3–4S Li-PoSpeed Control:60A brushlessWeight:200 g (7.0 oz)Overall Diameter:42mm (1.70 in)Shaft Diameter:5mm (.20 in)Overall Length:50mm (1.90 in)
Needed to Complete
60A brushless ESC
3–4S Li-Po or 10- to 14-cell Ni-MH/Ni-Cd
11x7 to 14x10 prop
MOTOR , LIPO WEIGHT ISSUE
If Motor/Battery Weight is a Issue, you may be able to use the E-Flite power 25, with a 3 Cell lipo and 60 amp ESC, and a 2600mah 3 cell lipo 40C
http://www.e-fliterc.com/Products/De...odID=EFLM4025B
http://www.hobbyking.com/hobbyking/s...idProduct=9947
Old 03-28-2011, 06:34 AM
Originally Posted by kenchiroalpha View Post
Hi Chellie
Great advice
Yours Hank
yes your right there Hank I like the cell pro, but with a 5 cell lipo, he will have to get the cell pro 10 I belive,
http://www.fmadirect.com/new_applica...0s_charger.htm
http://www.hobbyking.com/hobbyking/s...idProduct=7028
My flying club members like this Balance charger a lot, get 2 of these charger, one for a back up at $22.99 each, how can you go wrong
Old 03-28-2011, 06:36 AM
kenchiroalpha
Talking
Hi Chellie
I agreethat quite similar to my supermate and a great price
http://www.hobbypartz.com/60p-dyc-1004.html
Thats a very nice charger, sadly TP discontinued mine, wish i could get another
http://www.thunderpowerrc.com/html/cba/1010C.html
Yours Hank
Old 03-28-2011, 06:39 AM
they have 3 gyro types, but since your converting a heavy nitro PT 25 gyro to electric, you will need the larger power 32 e motor.
http://www.flyingbalsa.com/
The Doozy kit - e power
The PT profile - e power
The PT 25 Kit - Nitro
Old 03-28-2011, 06:49 AM
Default Wattmeter Instructions
[media]http://www.youtube.com/watch?v=kfs4Bs3H7gw&feature=player_embedded[/media]
Old 03-28-2011, 07:45 AM
Question
Hi Denny and Hank have some great info there too, its on a different Thread, We are all Happy to help out here if we can Take care, Chellie
Old 03-28-2011, 01:39 PM
Dr Gyro
Thumbs up My Request
WOW, What an outpouring of help from my request! Thank You guys and GAL for all the input. I feel like I have recieved so much informantion that when I go to my shop this morning, my conversion will have already been completed due to your input.
I am going to follow each link and read it all and go from there. I can't go wrong with all this info. I will keep you all posted on our progress. Thanks Again!!!!
Dr Gyro is offline
Old 03-29-2011, 04:00 PM
Dr Gyro
Default More Questions
Chellie, First of all I do Thank You for your input and realize that you went out of your way to send me all the links related to your recomended parts.
I have a few questions after reading the information.
After I learn to fly this autogyro I intend to build a scale model of a Bensen Gyrocopter. I would want to swap all electrics from this to the new one. The new Gyro will be built with aluminum tubing and may be a bit heavier than the PT. Will all my electronics be sufficient (power wise)for the swap?
You reccomended bigger engines and batteries for the trainer plane, Why?
The autogyro's have a lot more drag than the fixed wings. I used to fly a full scale Bensen (Still have it) and we used a lot more power (and fuel) for the same airspeed as a fixed wing with the same powerplant and similar weights.
Dr Gyro is offline
Old 03-30-2011, 02:13 AM
Hi Dr Gyro The GP Trainer is a Glow plane thats being converted to E Power, nitro planes are heavier than a E Power plane, so you need to use a E Motor that bigger than a 40 Equall to give you the power to fly right, on the gyro, that requires a 25 to 40 size glow engine, a power 32 Motor, will give you the power of a 40 nitro, they are a underated E Motor, with out being to heavy, Sooo what I wanted to do is Give you the power of a 40 nitro for the Gyro, and the power of a 50 Nitro for the GP trainer Plane, because the 40 GP Nitro trainer is heavier than than a 40 E Power Plane, and I wanted to give you the E power of a 40 Nitro for the gyro, with out being to heavy, If you feel you need more power than the 40 for the Gyro, use the same Power system for the GP Trainer, Look at the Motor weight and the battery weight to see if it will work for you with out being to heavy, weight is one of the killers with E power, its a Balancing Act to say the Least, Hope that helps, Chellie
Old 03-30-2011, 01:33 PM
Dr Gyro
Default Questions
Ok Chellie, That all makes sense to me. Forgive me for these petty questions but remember, this electric thing and R/C's are new to me. The gasser's are much easier to understand, fill it up and fly it. The transition from large full scale to micro is a learning experience to say the least.
Thank You for taking the time to answer my questions.
Here's what I'm moving down from!
Hope you have a Great day!
ID:	145606   Click image for larger version
Dr Gyro is offline
Old 03-30-2011, 05:51 PM
kenchiroalpha
Talking
Hi
Awesome machine
Did you build her yourself? and do you fly her on a regular basis?
Im quite jealous
Take care
Yours Hank
Old 03-30-2011, 08:05 PM
Dr Gyro
Default Gyrocopter
Hi Hank, Yes I built it myself. I found a Bensen airframe never assembled and went from there. I only flew this one three or four times and it has about four hours TTSN. Some personal things got in the way soon after I completed it and I just never flew it again. This gyro was my fifth gyro and I flew four of the others many times. I have not flow in over eight years and this one was just put up for sale. When I built it the basic kits on the market were $14,000. It didn't include the instruments, prerotator and lot of things on mine. I thought I could beat the 14K price....I was wrong by a long shot. New buyer gets a Great deal.
Dr Gyro is offline
Old 03-30-2011, 10:34 PM
kenchiroalpha
Hi
Thanks for the responce
Sounds like fun both the assembling and the operating
Ive been watching this for quite some time
http://www.cartercopters.com/index.html
Would like to try my hand at a scratch build rc version, one day
Take care
Yours Hank
Old 03-31-2011, 12:10 AM
Hi Dr Gyro Please feel free to ask all the Questions you Want If i dont know the answer, there are a Lot of People here, a Heck of a lot Smarter than me that Do and we are all happy to help out, Take Advantage of the Combined Thousands of years of experience Here, Take care and have fun, Chellie
Old 03-31-2011, 12:12 AM
Hi
Take care
Yours Hank
Me Too Hank
Old 03-31-2011, 12:34 AM
CrimzonRider
Hi
Take care
Yours Hank
OOOOOOOOOOOOOOO......I want that one!!! That would be awesome to fly!!
Talk about efficient, pretty good range, but why the depleted uranium in the wing tips? for ballast?
have a good one
cr
skynut
Delta & Flying Wings
04-01-2011 05:04 PM
B12
03-16-2011 10:56 AM
Skyydogg
02-24-2011 02:33 AM
lou1984
Batteries & Chargers
01-30-2011 09:54 PM
Saddlebum
01-19-2011 03:52 PM
Quick Reply: Conversion Assistance needed
Page generated in 0.11370 seconds with 16 queries
