Looking for rpm programmable ESC - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-18-2011, 11:13 AM
HugoW
Default Looking for rpm programmable ESC
Hi
To pilot race in the eq500 class, I need an esc with fixed top rpm. I would like to be able to program the esc linear to half throttle, and top rpm for the second half. So both rpm and curve need to be programmable. Which esc can i use? I could do the throttle curve on the Tx, maybe, but the top rpm isa fixed number (I believe 14k).
Hugo
Sent from my HTC Desire using Tapatalk
HugoW is offline
Old 10-18-2011, 11:51 AM
How many Amps does the Governor ESC need to be ?
http://www.rcgroups.com/forums/showthread.php?t=1178282
http://www.amainhobbies.com/product_...rce=google_ext
http://photoshipone.com/shop/index.p...index&cPath=28
Old 10-18-2011, 02:27 PM
Taking normal governed ESC's ... as used in some helis ... the RPM is fixed usually not as a user infinitely settable variable ... but as fixed steps ... therefore needing the Tx Throttle curve still to decide on actual RPM desired.
So what I would do with a governed ESC is select the next RPM step UP from desired ... and then Tx curve would bring it down to the desired Max (checking with a tacho of course) ... the intermediate points on the curve down to zero would then give the desired effect you look for by setting them accordingly.
I've never seen an ESC that can have RPM setting truly variable ... but then again I haven't seen a lot of things ...
Old 10-20-2011, 09:57 AM
HugoW
Default Re: Looking for rpm programmable ESC
Oh, it needs to be 70 amps or more, I now use a 100 amp cheap Himodel esc. I found Castle Creations to be programmable, but expensive and out of stock everywhere.
Hugo
HugoW is offline
Old 10-20-2011, 11:19 AM
5 to 12 cell lipo cells, 70 amp
http://www.hobbyking.com/hobbyking/s...hless_ESC.html
2 to 6 cell lipos 80 amps
2 to 6 cell lipos 85 Amps
http://www.hobbyking.com/hobbyking/s...w_5A_SBEC.html
Old 10-24-2011, 08:01 PM
HugoW
Thanks Chellie. Unfortunately, all those have no programmable top rpm number. I'll keep searching.
Hugo
HugoW is offline
Old 10-28-2011, 03:19 PM
philipa_240sx
Hugo,
It's a pretty tall order to find an ESC that'll do what you want. AFAIK, Castle Creations Phoenix ESC's are the only ones available with this kind of capability. Even then, the governor is designed for heli's not planes:
From the Castle Link Software v3.251:
Simple Governor Mode:
Simple governor mode is designed to be the easiest to use out of the box. You simply throttle up as if you were in ‘Heli-Fixed’ mode. The throttle stick is directly controlling the power to the motor, and NOT specifying rpm. Once you get to your desired rpm, leave the stick at that position for 1.5 seconds and the ESC will ‘lock’ onto that RPM. If you move the throttle, the head-speed will change accordingly. The only drawback to this mode is you do not know your exact head-speed.
Governor Low:
Governor low translates the throttle input to a pre defined head-speed. This mode will allow the motor to be governed at ELECTRICAL RPMs from 10,000 to 64,000. Note that electrical rpm is the RPM seen by the controller before taking into account gearing and motor type. You can determine what throttle value you will need for a desired head-speed by using the ‘Desired Head Speed’ inputs below. If governor low does not provide the speed you desire, switch to governor high and work your way up through the throttle until you achieve the desired speed.
Governor High:
Governor high translates the throttle input to a pre defined head-speed. This mode will allow the motor to be governed at ELECTRICAL RPMs from 50,000 to 210,000. Note, that electrical rpm is the RPM seen by the controller -- before taking into account gearing and motor type. You can determine what throttle value you will need for a desired head-speed by using the ‘Desired Head Speed’ inputs below. If governor high does not provide the speed you desire, switch to governor low and work your way up through the throttle until you achieve the desired speed.
Set RPM Governor Mode:
Fixed RPM will allow you to set 3 distinct head speeds that you would like to use. Simply enter the head speed and some vehicle setup information and Castle-Link will do all of the work to set up the controller for you. The first head speed is used for throttle inputs between 1.1ms and 1.5ms (up to 50% throttle). The middle head speed is used for throttle inputs between 1.5ms and 2.0ms (between 50% and 99% throttle). The last head speed is used for throttle inputs greater than 2.0ms (greater than 99% throttle).
solentlife described how a typical governor on other types of ESC's work. It's specifically designed for heli's to maintain constant rotor head speed regardless of load. It could be adapted to a plane, but once again it's not really meant to used in the manner you are looking for.
philipa_240sx is offline
05-28-2020 09:50 PM
arthersleep
09-12-2011 02:43 PM
philbel
Seaplanes E-Powered
09-09-2011 02:55 AM
11
09-06-2011 05:19 AM
KenSue
01-20-2011 10:09 PM
Quick Reply: Looking for rpm programmable ESC
Page generated in 0.05850 seconds with 14 queries
