Forsale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
General RC items For Sale and WTB List tools, RC simulators and any other RC related item that is generally classified
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra
Old 01-14-2012, 06:59 PM
terrynshed
Default Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra
This is a custom machined aluminum motor mount for the Multiplex FunJet and FunJet Ultra. It is designed to adapt a large range of motors for an excellent upgrade in performance. The alignment tab has also been machined into the mount to keep thrust angle adjustments simple. The mount is a direct swap with the stock plastic mount. Simply bolt on and you are ready to fly.
Two step installation:
1. Attach new motor to aluminum mount with the supplied screws
2. Attach entire assembly to the jet using the supplied mounting and thrust adjustment screws
Compatible Motors:
There are a large number of motor styles that will work with this mount. Here are a few examples.
MEGA Motors 16/xx series
28mm inrunners
36mm inrunners
28mm to 35mm outrunners
All motors included in the Multiplex power packs
Mount will work with all motors using the following bolt patterns: 16 x 16mm, 16 x 19mm ,19 x 19mm, 19 x 25mm, 25 x 25mm
If you have any questions with motor compatability, please contact me.
These are manufactured by Small Parts CNC. Please visit my website for more rc products.
Included: 1 FunJet / FunJet Ultra Aluminum Mount, 4 motor mounting screws, 3 mount / thrust adjustment screws. Weight: 7.7g
I can also substitute 'socket head' screws upon request.
I am selling the mounts for $15.95 each plus a fixed shipping of $2.00 in the US and $4.00 international.
Please send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
Name:	FunJet Mount 1.JPG
ID:	156366   Click image for larger version
Name:	FunJet Mount 2.JPG
ID:	156367   Click image for larger version
Name:	FunJet Mount 3.JPG
terrynshed is offline
Old 01-14-2012, 07:01 PM
terrynshed
Default Aluminum Motor Mounts for Multiplex, Parkzone, E-flite and Flyzone Planes
Below is a list of the RC plane manufacturers and models that I have designed custom CNC machined aluminum motor mounts for:
Multiplex Fun Cub, Mentor, Dog Fighter, Easy Cub, AcroMaster, Gemini, ParkMaster 3D
This mount is designed to adapt a large range of motors with bolt patterns ranging from 16mm x 16mm to 30mm x 30mm and all combinations in between. The mount is a direct swap with the stock plastic mount and includes cooling holes to allow better airflow into the cowl. This has also been known to eliminate the viration issues many people have been experiecing with the stock mount. No modification necessary.
Parkzone T28, Corsair, P-51D Mustang, Radian/Radian Pro, F4F Wildcat, Stinson
This mount is designed to adapt a range of 3530, 3536 and 3542 size brushless motors as well as the Heads Up RC Power up 480 motor to these Parkzone planes for an excellent upgrade in performance.
One of the key features to this mount is that it utilizes the stock plastic mount as a buffer zone in the event of a crash. The very inexpensive and easily replaceable stock plastic mount should take the impact instead of damaging the planes fuselage. No cowl modifications are necessary for the 3530 and 3536 series of motors (or 3542 on the P51), simply bolt on and you are ready to fly.
E-Flite Carbon-Z Yak 54, Apprentice
The Carbon-Z Yak 54 mount is designed to run a large variety of brushless outrunner motors utilizing 19x19, 19x25, and 25x25mm bolt patterns. It is also much stronger than the stock mount. Simply bolt on and you are ready to fly.
The Apprentice mount will work with the popular Power Up 25 and 3548 sized motors. One of the key features to this aluminum motor mount is that it utilizes the stock plastic mount as a buffer zone in the event of a crash. The inexpensive and easily replaceable stock plastic mount should take the impact instead of damaging the planes fuselage. No cowl modifications are necessary, simply bolt on and you are ready to fly.
Flyzone Select Scale Super Cub, Cessna 182
This mount is designed to adapt a 450 size brushless motor to the Flyzone Super Cub and Cessna 182 for an excellent upgrade in performance. This is designed to be a simple bolt on application. This is a much needed upgrade for these planes especially for float flying.
Please send me a PM if you are interested or have any questions regarding the mounts or motor compatibility.
Thanks for looking!
Terry
Name:	a. Multiplex 19x30.jpg
ID:	156369   Click image for larger version
Name:	b. Multiplex 16x19.jpg
ID:	156370   Click image for larger version
Name:	c. Corsair T28 Radian 3536 Mount.jpg
ID:	156371   Click image for larger version
Name:	d.  P51 3536 Mount.jpg
ID:	156372   Click image for larger version
Name:	e. CZ YAK 54 Mount.jpg
Name:	f. Flyzone Super Cub Motor Mount.jpg
ID:	156374   Click image for larger version
Name:	g. Corsair T28 3536 Mount.jpg
ID:	156375   Click image for larger version
Name:	h. Flyzone Super Cub Motor Mount.jpg
ID:	156376   Click image for larger version
Name:	i. CZ YAK 54 Mount.jpg
ID:	156377   Click image for larger version
Name:	j. apprentice 3548 mount.jpg
Old 01-14-2012, 07:02 PM
terrynshed
Default Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount
This CNC machined aluminum two piece mount is designed to adapt a large range of outrunner motors to the Multiplex Easy Star. It will allow for three different motor mounting heights to accommodate propeller sizes ranging from 6" to 8".
With this feature you can easily run a lower KV motor with a larger propeller for more thrust and better efficiency. This would be a perfect combination for FPV pilots looking for longer flight times and a more quite platform.
Swapping motors from a 35mm outrunner with an 8" prop to a 28mm outrunner with a 6" prop can easily be done by removing a few screws. This is ideal for those looking to achieve the best performance possible.
Position 1: stock height up to a 6" prop.
Position 2: (+) 0.41" for up to a 7" prop.
Position 3: (+) 1.0" for up to an 8" prop.
Compatible Motors:
28mm Outrunner
35mm Outrunner
Acceptable bolt patterns (mm): 16x16, 16x19, 19x19, 19x25, 25x25
Due to the large variety of compatible motors, please verify motor size and KV will suite flying style. Contact me for any questions regarding motor compatibility
Three step installation:
1. Glue motor base tube into the fuselage (nacelle) making sure mounting flange is square.
2. Attach new motor to motor plate with supplied flat head screws.
3. Attach motor plate to motor tube at desired height with suppled pan head screws.
Included: 1 - Motor Base Tube and Motor Plate, 4 motor screws and 4 mount screws.. Weight: 20g
Notes: A 35mm outrunner motor will only fit in Position 3 (+ 1.0"). 28mm outrunners will work in any of the three positions. The stock thrust angles are retained in all 3 positions. If a change in thrust angle is desired, simply add a small washer between the motor base and motor plate at the appropriate locations.
Price is $15.95 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
Name:	ES Mount 1.jpg
ID:	156379   Click image for larger version
Name:	ES Mount 2.jpg
ID:	156380   Click image for larger version
Name:	ES Mount 3.jpg
ID:	156381   Click image for larger version
Name:	ES Mount 4.jpg
ID:	156382   Click image for larger version
Name:	ES Mount 5.jpg
Name:	ES Mount 6.jpg
Old 01-14-2012, 07:06 PM
terrynshed
Default 10mm Billet Aluminum Stick Mount for 28mm and 35mm Outrunners
This aluminum stick mount is designed to fit models using a 10mm stick for mounting motors. It will securely attach to any 10mm stick allowing for a large range of 28mm and 35mm outrunner motors to be used. It is CNC machined from 6061 billet aluminum making it very strong.
One key feature of this mount is that the motor shaft and propeller are positioned just below the stick.
Thrust angle washers are included to adjust for proper thrust angle if necessary.
Distance from bottom of stick to center of motor shaft is 6mm.
Depth of tube (part that slips over the stick) is 10.7mm
Compatible Motors:
28mm Outrunner
35mm Outrunner
Acceptable bolt patterns (mm): 16x19, 19x19, 19x25, 25x25
Installation:
1. Attach new motor to aluminum stick mount.
2. Attach mount to 10mm stick with one of 2 options:
a. use 4 self tapping screws (#4 or 3mm) to secure at each mounting hole.
b. use 2 screws and 2 nuts (#4 or 3mm) to secure completely through stick on top and side
Included: 1 - 10mm Aluminum Stick Mount, 4 Thrust Washers.. Weight: 3.6g
Notes: To adjust for proper thrust angle simply install the washers between the motor and mount at the proper locations.
Price is $9.95 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
Name:	10mm Stick Mount 1.jpg
ID:	156385   Click image for larger version
Name:	10mm Stick Mount 2.jpg
ID:	156386   Click image for larger version
Name:	10mm Stick Mount 3.jpg
ID:	156387   Click image for larger version
Name:	10mm Stick Mount 4.jpg
ID:	156388   Click image for larger version
Name:	10mm Stick Mount 5.jpg
Name:	10mm Stick Mount 6.jpg
Old 01-31-2012, 11:49 PM
Nitro Blast
Nitro Blast's Avatar
It looks to me like the Dogfighter model will work in the Mentor?
Can you advise, and if so I'll grab a couple.
Nitro Blast is offline
Old 02-01-2012, 12:26 AM
terrynshed
Yes, the Dogfighter and Mentor mounts are the same.
For the Mentor you will want the Multiplex 19x30 Universal. This will give you the 19x25, 25x25, and 30x30mm bolt patterns.
Terry
Old 02-01-2012, 05:06 AM
Nitro Blast
Thanks for the prompt reply Terry!
I don't know why I didn't see it before. Tks.
Old 02-01-2012, 05:11 AM
terrynshed
Your Welcome.
These adds don't have a lot of info in them. I tried to keep them short and basically list what models I have mounts available for.
Terry
Pusher Park Jets
21
07-28-2015 03:34 AM
Mr.Clean
Delta & Flying Wings
11
08-16-2011 09:25 AM
TylerJCooper
Pusher Park Jets
24
06-11-2011 07:44 PM
terrynshed
02-18-2011 04:11 AM
Quick Reply: For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra
Page generated in 0.07344 seconds with 40 queries
