warped wing - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
warped wing
Old 11-06-2010, 10:03 PM
royz
Default warped wing
What can I do to fix my warped wing problem? I just got a foam Cessna 182 from Art-Tec thru Hobbie Lobbie. The main wing has a little anhedral instead of a little dihedral ( in other words it curves down instead of up ). Is there a way to fix this? The wingspan is about 38" and.The servos are already mounted in the wing. Thanks in advance. I have a lot of experiance, but am new to foam.
royz
royz is offline
Old 11-06-2010, 10:22 PM
Catalina
Do you know what type of foam it is? If EPO, you can run some hot water over it, or use hot steam, then you can manipulate by slowly bending it back.
Has it got a wing spar?
Catalina is offline
Old 11-06-2010, 11:51 PM
Twmaster
Registered User
Twmaster's Avatar
If you just got this I'd call Hobby Lobby and ask for a new wing. They are very good about customer service.
Twmaster is offline
Old 11-07-2010, 01:09 AM
gramps2361
gramps2361's Avatar
I had one of those the wing did have a slight anhedral to it not a lot but it did have some.I want to say this is built in to the wing, so that in flight the wing straightens out under load. If you notice there is no wing struts with this pane to stop the wing from flexing in flight, hence the anhedral.
gramps2361 is offline
pox67
WWI Era
11
02-29-2008 12:52 PM
jasmine2501
09-29-2007 01:28 AM
jeffsend
Delta & Flying Wings
09-29-2007 12:19 AM
barmonkey
01-26-2007 08:25 PM
mjswider
Foamies
11-29-2006 02:00 PM
Quick Reply: warped wing
Page generated in 0.05384 seconds with 13 queries
