Cant get LIPO to charge - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-26-2010, 06:21 PM
George Hayes
Default Cant get LIPO to charge
I have a ElectriFly BP300 which will not charge.I have a Electifly Poly Charger with a Equanox attached.The battery is almost new.I have chager other batteries with no problem.Cant get the Equinox to function. Does not light up!!George!!
George Hayes is offline
Old 11-27-2010, 12:28 AM
Hi George check your battery voltage, if its less than 2.9 volts per cell, the charger may not want to turn on, if i remember right the equanox balancer has to have the buttons pressed twice to get it to turn on,
the charger needs to be set to 250mah if your using the single poly charger, they have a poly charger and a poly charger 4, check your balance plug wires too,
if everything is ok, then you may need to use another charger, the small poly charger may not want to work with a equanox set at 250 mah and a small 300mah lipo.
Old 11-27-2010, 12:38 AM
Twmaster
Registered User
Twmaster's Avatar
George, if possible try to charge the pack without the balancer. This may help determine where the problem is.
Twmaster is offline
Old 11-27-2010, 06:38 PM
George Hayes
Default Tryed charging without Balancer
I diconected the balancer and Direct Charged from the Polly Charger.I get a 7 Second charge and then it startd beeping???George!!
Old 11-27-2010, 07:33 PM
How many cells and what is the resting voltage of the pack?
Old 11-29-2010, 12:39 AM
George Hayes
Default Charging Problem
BP300 is a 7.3 Volt 2 Cell Battery.
Old 11-29-2010, 01:20 AM
do you have a volt meter, the question that is being asked, is what is the voltage showing on your lipo, a 2 cell lipo is 7.4 volts, if your lipo is at 7.4 volts or higher it wont charge anymore, what is needed too, is the individual cell voltage, that can be taken at the balance plug, if you dont have a volt/ohm meter, they are cheap at harbor freight tools, like about $5.00
http://www.harborfreight.com/7-funct...ter-92020.html
Old 11-29-2010, 01:55 AM
George Hayes
Default Voltage reads Zero,is Pack Shot??
Old 11-29-2010, 02:40 AM
Yep just might be....
Old 11-29-2010, 05:06 AM
Yep, That lipo is DEAD, if a lipo goes below 2.9 volts per cell, the lipo will become ruined, recycle it and get a new lipo they are cheap enough
Old 11-29-2010, 12:00 PM
Rodneh
If it is truly a zero voltage reading, you most likely have an open lead as even a bad LiPo reads a slight voltage if all the leads are connected. Depending on where the open is, you might be able to repair it.
Rodneh is offline
nipper
06-06-2011 08:45 PM
nipper
02-11-2009 06:11 AM
diablo
04-21-2007 04:42 PM
Vendetta
10
02-13-2006 04:43 AM
JimClark
29
12-05-2005 09:58 PM
Quick Reply: Cant get LIPO to charge
Page generated in 0.09997 seconds with 13 queries
