Help me decideon prop size, please.
Old 03-24-2013, 08:59 PM
HugoW
Default Help me decideon prop size, please.
Hi,
I'm putting together a no-name ARF P51, span 1600mm, AUW I'm aiming at 4kg. I will run it on a 6S pack, 80A ESC. I found an old Turnigy C5065-400 in the workshop, which I think is the one to use. But the HK site does not show it anymore and I don't find good references. I would like peak around 60-70A. How do I determine what prop to use, without buying a dozen and try?
Thanks,
Hugo
HugoW is offline
Old 03-24-2013, 10:41 PM
Originally Posted by HugoW View Post
Hi,
Thanks,
Hugo
Check out those computer programs such as www.motocalc.com, (Free for 30 days, then $39 USA). With these programs, you input the motor specifications, motor battery, range of propellers, model wingspan/area, and motocalc spits out its opinions on what will work.
Problem is Turnigy doesn't provide the winding resistance of their motors, and that easily measured winding resistance is critical on how the motor will perform. This winding resistance can be measured with a pair of voltmeters, a battery and a power resistor, even an automotive tail light will work.
Measuring Brushless Motor Resistance
http://www.wattflyer.com/forums/showthread.php?t=50740
As indicated, there are also other free computer programs with a bit less capability.
As for conversions of a glow type model airplane to electric power, with the very high power capabilities of the modern brushless motors, it's not hard to come up with a package that can and will equal or even exceed flight performance of that model with a glow power system. Big advantage of glow, is longer flight times. Even so, 6 minutes flying time with electric is not hard to achieve.
I've posted these threads on "Electrifying medium size models" in wattflyer many times, take a look:
Hangar 9 Kantana Model
AEAJR's Site on Electric Power
http://www.wattflyer.com/forums/showthread.php?t=18521
Old 04-01-2013, 02:15 AM
Dr Kiwi
http://www.draneer.com/OlympicFlying...a330L_Dendron/
He used 15x7x3 on 6s
Dr Kiwi is offline
admin
01-12-2021 11:21 PM
05-28-2020 09:50 PM
wilinfla
04-11-2015 12:33 PM
planefixr
12-07-2012 01:16 AM
KenSue
Foamies
04-14-2011 08:34 PM
Quick Reply: Help me decideon prop size, please.
Page generated in 0.07342 seconds with 13 queries
