Watts in an ESC - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Watts in an ESC
Old 12-11-2018, 09:21 PM
Jack_Hammer
Veteran USAF
Jack_Hammer's Avatar
Default Watts in an ESC
Catchy title huh?
A neighbor brought me a 30a esc with the plastic wrap removed (I didn't ask why. Too late)
an he was curious what the metal plates were for as well as the white goop under it.
I wasn't 100 percent sure, but I thought it was for cooling. Sort of like a heat sink with cooling fins only the fins aren't necessary. The goop simply distributes cooling at the point of contact on the circuitry and more evenly.
But I told him to know for sure it's best to ask the knowledge base here on WattFlyer.
Is this ESC now rendered unusable?
File Type: jpg
File Type: jpg
Jack_Hammer is offline
Old 12-11-2018, 10:16 PM
hayofstacks
hayofstacks's Avatar
The metal plate is a heat sink, and the goop is thermal paste.
Should be pretty much the same stuff they use for computer cooling stuff. The plastic holds the plate on. I have put heatshrink on top of esc's before. I would try to leave some of the heat sink open to air, just to help with cooling.
Throw it back together, make sure it still works, and let it rip.
hayofstacks is offline
Old 12-11-2018, 10:24 PM
Jack_Hammer
Veteran USAF
Thanks, like I said, I had a good guess here. I've been out of the loop in the hobby for awhile. Things have changed. He says it works fine. I'll wrap it up as you described and hope he doesn't come back to get it
Old 12-12-2018, 01:14 PM
Its a good trick actually to cut way a square of the heatshrink that is over that plate to let it pass heat better.
The plate of course being flat leads to many people fixing the ESC in place with double side tape using that flat plate - WRONG !! That plate should be the side that is not taped to the model ... One day ESC's will have flat fixing side as well !!
Old 12-26-2018, 12:46 AM
dereckbc
The plastic wrap as you call it does two things.
1. Holds the heat sink to the ESC.
2. Electrical insulation.
Cut it off and use tie wraps to secure heat sink, and ensure it does not make electrical contact with anything. It will run cooler which is a good thing.
dereckbc is offline
Old 12-26-2018, 04:24 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
The metal plate is a heat sink, and the goop is thermal paste. ...
And as usual way too much thermal paste because the manufacturer cannot be bothered to install the FETs correctly. I.e. same height and in same plane.
Thermal paste conducts heat better than air, but compared to aluminium it is a rather poor heat conductor.
Sand components on flat sandpaper, the surfaces of the FETs must have same height and their top surfaces must be in same plane. End with fine sandpaper. Apply paste to components and to heat sink. Scrape all excess paste off with credit card, there should only be paste in the (micro)pores. Install heatsink again.
ron_van_sommeren is offline
Old 12-26-2018, 11:26 PM
In my view the shrink wrap does a good job of thermally insulating the ESC.
This tends to mean the heat sink is just that, it absorbs the heat from the component hot spots and distributes it away into the aluminium. The thick shrink wrap means very little heat is then transferred to the outside air.
For a normal duration electric flight it is likely stopped before the heat sink gets so hot that it is no longer absorbing any further heat.
Now if you replace the flat plate with a finned (or better still fingered) heat sink placed directly in the air flow then a steady state is reached (the ESC never gets any hotter) with only a modest temperature difference.
The fingered heat sink on my EDF Fairey Delta 2.
The heat transfer is so good that if flown on really cold days the ESC fins are at ambient by the time you reach the plane but the same could not be said for the EDF motor!
quorneng is offline
05-28-2020 09:50 PM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
15
04-14-2013 07:32 AM
11
09-06-2011 05:19 AM
Quick Reply: Watts in an ESC
Page generated in 0.09665 seconds with 15 queries
